Used to have problems with the silver solder flowing into the contact areas, so I built this simple jig below. Use the mini-torch and regular electrical solder to fill up the connector ends, and 60/40 silver solder on the wires. With the connector in the jig, heat the bullet solder & wire with the mini-torch until the wire can be fully pushed into the bullet. After it cools down, I clip off excess solder leaked out of the holes in the bullets with dikes & use a flap wheel to smooth things up prior to adding the heat shrink. JIM
NOTE: It's just a piece of >1/2" thick aluminum plate with holes drilled the same size as the "connector" OD part of the bullet to hold them in place & eliminate excess solder flow.
