100 amp esc? reviews/info?
  • drgreenthumb91
    • Jan 2008
    • 14
    Anyone every heard of this thing?
    Any good?
    Are the specs listed legit?
    Looking to put twins in a 45" mono for cheap >.<
    Weight:85 grams / 2.99 oz. Size: 70 x 40 x 20 mm 2.76 x 1.58 x 0.79 in. Constant Current: 100A Max Current: 125A / 5 Sec. FET: Many BEC: No TIMING: Programmable - 1/7/15/30 PWM: Programmable - 8/16K Input: 4-6 cell Li-Poly or 12-21 Ni-MH Low-Voltage Cutoff: Programmable * Features: Finned aluminum heat sink * Low resistance * 8-16KHz PWM * For 12-20 NiCd/NiMH cells, 4-7 Li-Poly Cells * 100A Continuous, 125A Max for 10 seconds * User programmable brake * User programmable low-voltage cutoff * User programmable throttle settings and rotation direction * User programmable timing advance * User programmable PWM * Throttle range self-adjusting * Soft start ramp up * Auto motor cutoff with reset * Safe power arming program ensures motor will not run accidentally after turn on * Low torque start * Auto shut down when signal is lost * For outrunner motors, use 15° timing and 16Khz PWM Note: This ESC has no built-in battery eliminator circuit (BEC). You will need a 4.8V receiver pack or an external switching BEC to provide power to your receiver.
    Picked up a few for 43$ a piece i know its a bad time to ask after lol.
    Current project 45" aeromarine xXx twins.
    I came here to do two things Chew bubble gum and Kick ass, And im all out of bubblegum.
  • SJFE
    • 4735
    Looks like a HighModel unit. If that's the case you can prolly pick it up direct for about half that. They seem to be decent esc's
