rudder lenth (df26) and general guidelines
  • dana
    Banned
    • Mar 2010
    • 3573
    i hate the cheap rudder i got for my df26. its just not great quality, but also im curious if my rudder is causing more harm than good. its a 3' rudder form bottom of bracket to tip. is this too long? i was looking at the speedmaster mini rudder, which says 4", but the quality is much better than what i have now. any thoughts? suggestions? heres a crappy video, i didnt catch much of the turning because im still messing with my video camera/hat contraption, but you can hear the prop jumping in and out of the water. thanks guys
  • dana
    Banned
    • Mar 2010
    • 3573
    C'mon nobody's got any advise here? I'm ready to buy a rudder. Should I go longer or shorter?
    • runzwithsizorz
      • Jan 2009
      • 896
      http://forums.offshoreelectrics.com/...r-relationship
        • 7673
        I've been lucky cutting mine down(haven't gone too far).Take two rudders,cut one down a 1/4 at a time and test,repeat till you start to lose the desired steering.Then leave the second one a 1/4" longer and you should be fine.You could use this one you don't like to experiment with.Unless you are going to change the width drastically with the new one. Does that little 26" carve like a DF should?
        • dana
          Banned
          • Mar 2010
          • 3573
          Well, I can say that it turns ok. Not great IMO. The tolerances on the current rudder aren't good. Lots of play in there. Cutting the crappy one for testing is a good idea. If you watch my video, you can hear the prop. Should give a good idea what's going on. I noticed the new revolt has a short rudder I think. Got me thinking....
            • 7673
            I took quite a bit off my rudder for my cat.You can run a broader blade for more effective area and turn down your Expo on the TX.
            • dana
              Banned
              • Mar 2010
              • 3573
              It seems like there's a serious lack of quality 3" rudders. 4" and up they're well built and nice, anything smaller and it's crap
                • 7673
                This is an example of that quality,the small inlets are unacceptable to me.The bracketry is interchangeable on these.Just a matter of who ordered them and for what $
                Maybe get the 4" and cut it down to the desired 3"
                  • 7673
                  Grab one of these and cut it to the water pickup.Then you will have a 3" blade. http://www.offshoreelectrics.com/pro...prod=ose-80050
                  I have a couple of these so I measured it.
                  • dana
                    Banned
                    • Mar 2010
                    • 3573
                    Thanks for the help man...
                    • dana
                      Banned
                      • Mar 2010
                      • 3573
                      i ended up grabbing the speedmaster mini. was pricey compared to the $15 rudder i had, and believe me, the quality is wayyy better! had to cut the mount a bit cause the footprint is too large for the little df, but its on there. test tomorrow
                        • 7673
                        Can't wait to see the results
                        • dana
                          Banned
                          • Mar 2010
                          • 3573
                          The new rudder worked nicely. Seemed much more stable... Not sure if the play in the old one was causing some of the squirrel like behavior, but I'm very happy with the new one. It's nice living 20 minutes from ose, I get my stuff really quickly in the mail
