Lehner motor and schulze esc
  • Alexgar
    • Aug 2009
    • 3534
    I just recieved a combo i bought off ebay and im stoked I havent decieded if i should use it in a 4x4 slash or a boat The motor is a 18.97 kwf water proofed and finned the motor is a 1940/7 lmt i have othe esc for the boat if a higher limit is necessary, if you have run this motor please let me know what you think
  • jcald2000
    • May 2008
    • 774
    Well, I run a 1940/8 in a rigger And pull 120 amps ave. with a high of 150 amps on startup with a 645 prop. Yours is a hotter motor so I would start around a 440 prop on 4s.
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1837
      What year of manufactor? Should say on the motor. Make sure it runs smooth it looks a bit old. It's not a hiamp version. Still a lehner though.
        • 8011
        That is an older LMT motor. The endbell can be configured as either a Star or Asterix wind (7 or 12 turn I think), I can't remember which based on the cuts in the solder on the endbell. Kvs would be around 2240 and 1330 rpm/volt depending on the endbell. Contact Lehner for more up to date info.
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1837
          Should be good for 5s and 8s, but check that it runs smooth.
          • jkr
            FE Addiction
            • 568
            A friend had it on a H&M speedman 4s1p esc t120 and prather s220.
            The speedman is 750mm mono2
