df 25 help
  • driftah
    • 760
    df 25 help
    I am looking for a suggestion on what all you guys prefer as a setup in a df26 hull for good top end but not a saw setup,I have heard ul1 blah blah but looking for an alternative to do well on 4s1p.I also saw using lower kv motors on like 45mm props but am leery on that stuff.I wanna go fast but not stupid fast.as well would using a feigao 540xl series motor be too high a cog on this hull mine kinda skipped sideways on this xl setup...maybe a lighter setup would perform better???? suggestions
  • RIPFENCE
    • Sep 2009
    • 1332
    something with a 2200kv like the castle 1515..i had good results low 50's x642 prop and was a blast to drive.. i could have proped up a bit too.. i noticed that this hull was extremely sensitive to the movement of batteries as well as strut angle took a while to get totally dialed..
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
    • dana
      Banned
      • Mar 2010
      • 3573
      im using leopard 2200kv with x640 and im seeing high 40's and touched 50. still playing around with props
      • dana
        Banned
        • Mar 2010
        • 3573
        you could try a turnigy 3665 2300kv available from kintec for 50 bux. i use one in my ul1 and get low 50s
        • driftah
          • 760
          wowsers a castle 1515 thats a monster.wondered how a proboat 1800kv motor or ul1 would do? is bigger better in this hull I was tryin to keep it smaller lol
          • Basstronics
            • Jun 2008
            • 2345
            Leo 3674 would probably be limit.
            I was going to try a 4074 in it but was advised not to. A leo 36XX motor with proper KV with your desired packs would be the best choice. Unless you can afford the more expensive motors.
            • dana
              Banned
              • Mar 2010
              • 3573
              im using 4074, and its not even enough really. the boat is at 50 and can handle more 'SHRUG"
              • driftah
                • 760
                heck that motor weighs more than the whole boat.maybe I will see if I can snag a 1515 or a 4074 to try.I do like fast lol
                • dana
                  Banned
                  • Mar 2010
                  • 3573
                  Well, I thought I was overpowering mine until a few very experienced guys chimed in and confirmed I was not. I can say the motor doesn't get warm at all after a good run
                  • Chuck E Cheese
                    • May 2008
                    • 1684
                    these boats rip on neu 1515 or 1415 1y
                    see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
                    • Basstronics
                      • Jun 2008
                      • 2345
                      Dang and people thought I was nuts when I put a 4074 in it.
                      I guess if you had luck like that, do it again!
                      • Heath M
                        • Mar 2008
                        • 806
                        feigao 8xl and a M445 prop on 4s1p and that boat will be ballistic.
                        Brisbane,QLD, Aussie
                        • Chuck E Cheese
                          • May 2008
                          • 1684
                          they run real good on an 8l 3s as well...
