Oopppss
  • shawnboat
    • Feb 2012
    • 43
    Oopppss
    So after I got my ESC/BEC/MOTOR situation working. I attached the drive shaft and....Bang!
    The driveshaft is 1/4 and I have no idea what happened, has anyone seen this before?
  • tryinotocrash
    • May 2012
    • 190
    Did it run backwards?
    Don't forget to put your brain in gear before you engage your mouth! Thanks Dad!
    • shawnboat
      • Feb 2012
      • 43
      to be honest with you, I have no idea. it happened so quick. A definate possibility tho. could that be a cause?
      • tryinotocrash
        • May 2012
        • 190
        Not sure but you could look and see if it is wound backwards from the other half of it. I had no idea this could happen..
        • dana
          Banned
          • Mar 2010
          • 3573
          Well, you're cable is for props that run counterclockwise. Is that the direction you prop runs?
          • Make-a-Wake
            FE Rules!
            • 5557
            Give your motor a blip of the throttle with nothing on the shaft and see which way it spins...........if it is hooked up to spin clockwise then thats your problem, just swap any two motor wires to reverse direction if so..................
            • shawnboat
              • Feb 2012
              • 43
              haha, damn. Looks like my prob runs clockwise.
              • shawnboat
                • Feb 2012
                • 43
                I take that back. Looks to be counterclockwise after doing some more research :)
                • Make-a-Wake
                  FE Rules!
                  • 5557
                  How about the motor?????
                  • shawnboat
                    • Feb 2012
                    • 43
                    The motor is going clockwise, that'll mix everything up. haha. Ill have to order a new driveshaft, and switch 2 of the leads on the motor
