Another problem
  • shawnboat
    • Feb 2012
    • 43
    Another problem
    Hey all again
    I am having a problem with my leopard motor. When I plug it in, it continuously beeps. And the shaft wont move at all. The battery is fully charged. I made a little video
    Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    I plug in my motor and I get nothing at all not even beeps so you are one step ahead of me....
    You plug the motor to what, battery, just like that???
    You can't do that!!!
    Try to connect the motor to ESC that is properly set up for the battery you are using and make sure your receiver and transmitter are properly set up with your esc...
    Canada
    • izcain
      • Mar 2012
      • 274
      It almost looks like you dont have all the wires hooked up but I can't really see them well enough in the vid. Post a pic of how you have everything hooked up
      • shawnboat
        • Feb 2012
        • 43
        Here is a picture of the set up. In the instructions it said the ESC should beep with plugged in, and its not beeping (just the motor is beeping)
        • BHChieftain
          Fast Electric Addict
          • 1969
          Check that your throttle trim on your TX is set to zero. Also, in your picture the ESC isn't connected to your RX, make sure that is hooked up.
          Chief
          • puttekula
            • May 2011
            • 85
            The esc never beeps. The motor does however...
            • shawnboat
              • Feb 2012
              • 43
              Correct
              • shawnboat
                • Feb 2012
                • 43
                hobbywing seaking 130A-HV ESC
                • Rumdog
                  • 6453
                  Does that esc have a bec built in? My guess is no.
                  EDIT* Just checked. It doesn't. You need a rx pack or external bec to power up the rx.
                  • martin
                    • 2887
                    According to the specs ive seen on the Seaking 130a esc theirs no bec.
                    • shawnboat
                      • Feb 2012
                      • 43
                      Thanks very very very much guys, the motor is working. Love this site
                      • paultbg
                        • Mar 2012
                        • 103
                        Another Seaking 120A with problems
                        Hello
                        As an unwanted following to the above situation, my esc/radio started today to act strange:
                        When I connect the power the engine is beeping continuously like the transmitter is not started and is not detecting the lipos.
                        However the radio is working and matched between them.
                        And to be even more strange the throttle (engine ) is not working while the servo is working fine.It is possible that the throttle on tx is not working anymore?
                        If i put the engine/bec on 3'rd channel (used for binding) suddenly the esc detect the batteries and start running at high power, continuously.
                        On this stage I can not control the throttle.
                        Until today everything was running ok.What am I doing suddenly wrong?
                        Is the tx/rx faulty?
                        Please advise me if you have some experience.
                        The ESC is this one:http://www.hobbyking.com/hobbyking/s...idProduct=8946
                        The tx/rx: http://www.hobbyking.com/hobbyking/s...Ch_Tx_Rx_.html
                        Thanks a lot
                        • G-UNIT
                          • 949
                          When mine did that I disconnected the battery, hold throttle wide oped and connected the battery again whike holding and reprogram the esc, just a thought.
                          I dont know whats going on with t120 I think I may have burned them up becauce when arming they program just fine and power the rudder but not the motor and the esc gets hot just holding it.
                          one esc ran away like you said and started sparking before I could disconnect the battery, now I'm alittle woeeied about trying them again and see if there still working, never had any real problem with them befor but I do push things to the limit.
                          first the bec stoped working on 5-6s then it seemed that things started going wrong,
                          I am going to get another t120 and also a t180 very shortly, I hope you get yours sorted out, but try and reprograming it. Good luck
                          • paultbg
                            • Mar 2012
                            • 103
                            Hello
                            I have made some more testing last night and I am almost sure that it's a radio problem.
                            When i put the bec on first channel (servo channel) the esc is arming and I even can program the esc byt using the wheel instead of trigger.
                            In the same time, the servo connected to second channel (bec's channel) is not responding at all using the trigger.
                            So, as conclusion, either the trigger from tx is not working or the second channel (bec channel) of the rx died.
                            I do not have any experience with tx&rx systems, but do you guys thinks that is possible? Please advise.
                            Regards
