Hey everyone. I finally got sick and tired of messing around with my disagreeable Miss Elam (just gave that hull away) so I am looking for something different, maybe a shallow V. Setup is a UL-1 motor, SeaKing 180 and 6S. Any suggestions? Thanks!
Looking for fast 6S hull suggestions...
Tags: None
The motor has held up very well under 6S power so far. If it goes bad it goes...it is what I have to deal with at the moment. I have all my boat cash tied up in an 8S Genesis. This is more of a bargain setup. I'm using two 3S 4,000/5,000 packs.Comment
Because it is terribley inefficent. There becomes a point of diminishing returns when you use excessive voltage on a motor than doesn't have the power to turn that fast. You're not getting 6s RPM out of that motor, unless you are using a prop that's way too small for that application. You would be surprised how well a proped setup would run.Comment
Delta force 29 or 33" cyber storm are great mono hulls very fast. Or a mean machine cat.
Only thing will be what you get away with in a hydro may not work in a mono or cat.Comment
