running Hot!!! help!!!
  • corvette kid
    • Apr 2012
    • 8
    I am a newbie and i have some learning to do. i just bought a hk genesis and im running the stock motor which is a 2075kv motor with a 125a esc and 5000mah 2s 45c x2 batteries in series. still using the stock prop. i dont have a temp meter but esc, motor, and wiring is hot to the touch. any thoughts???
  • dana
    Banned
    • Mar 2010
    • 3573
    You may be running too long. When the lipos start to drop their voltage, it happens quickly, and things get very hot fast. Where is to lvc set to? Time your runs if you can. Upgrade to 5.5 bullets if you haven't. What's your timing set at?
    • corvette kid
      • Apr 2012
      • 8
      the boat is running like a rapped ape so i was hopping i didnt need to program anything and i dont have a programming card to set it! here is my esc- http://www.ebay.com/itm/TURBOJET-120...ht_2536wt_1037 what next???
      • Doby
        KANADA RULES!
        • 7280
        Required.
        Radio System (2ch) & Receiver
        1 x 3kg standard size servo
        100A ESC
        3300mah 3S 20C Lipo or greater
        *Spare parts and accessories arriving soon!
        Quote from HK's web page.....its a 3S boat, you are running 4S.
        Grand River Marine Modellers
        • LiPo Power
          DJI Drone Advanced Pilot
          • May 2009
          • 3186
          You can run 2 x 3S in P Configuration, problem solved!
          Canada
          • corvette kid
            • Apr 2012
            • 8
            Originally posted by Doby
            Required.
            100A ESC
            The manual that came with the boat says it requires 14.8v 4000mah 25c batt 125 esc and 3kg servo. on hk promo video for genesis they ran it on two 2s batts with a 120 esc.
            • dana
              Banned
              • Mar 2010
              • 3573
              2075 is more a 4s motor. Although it may not be a great motor to start with.
              • Doby
                KANADA RULES!
                • 7280
                OK, so what are the results from running 4S....lots of heat...remember, the motors they put in those things are el cheapo and not very efficient...run 4S at your own risk......
                Put a smaller prop on it...if you want to run 4S.
                • LiPo Power
                  • May 2009
                  • 3186
                  Ok, use smaller prop, check how easy your shaft spins, lubricate again, check cooling, change connectors to 5.5mm, try again.
                  IMO this motor is good on 3S ( they say up to 4S but that is Chinese statement )
                  Other people reviews calling for 3S on this motor....
                  Canada
                  • LiPo Power
                    • May 2009
                    • 3186
                    LOL, post on the same time Doby, ...
                    Canada
                    • dana
                      Banned
                      • Mar 2010
                      • 3573
                      I did mention its prolly not a great motor. But 3s on that kv is boring
                      • corvette kid
                        • Apr 2012
                        • 8
                        as soon as it goes im going to leopard 2200kv.
                        • LiPo Power
                          • May 2009
                          • 3186
                          You are right dana but we all know from our experience how Chinesse marketing, specs and other staff works.
                          Here is their parts to make it as recomended COMBO
                          Canada
                          • LiPo Power
                            • May 2009
                            • 3186
                            Upgrage motor
                            Canada
                            • dana
                              Banned
                              • Mar 2010
                              • 3573
                              Leoard will kick butt! Yes some of the Chinese stuff is def over rated
