mounting alum motor mounts
  • Chuck E Cheese
    • May 2008
    • 1684
    how are you guys mounting the alum rails for the leopard motor mounts to the hull. i have always been a big fan of glassing the rails to the hull but glass (or epoxy) doesnt stick to metal... just curious, i am mounting a 5692 and need a good bond to the hull.
    thanks
    see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
  • madmorgan
    Banned
    • Jun 2011
    • 152
    i think if you drill some small 1/16 holes into them side rails you will be able to glass em in. someone else with more boat knowledge might have better solution though.
    • JIM MARCUM
      • Jun 2011
      • 773
      One way is to screw On a aluminum 1/2" "L" on the inside of the mount (it's too pretty to cover up the RC BOAT BITZ), drill a row of 1/8" holes along the angle, and epoxy it in place with 1" fiberglass tape. Scruf up the aluminum angle and deck with coarse sandpaper & wipe everything down with acetone. But you gotta be sure the stuffing tube is perfectly aligned with the motor shaft as you epoxy it in.
      Crude dwg below. JIM
      JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
      • Make-a-Wake
        FE Rules!
        • 5557
        Most mounts have the pre-drilled holes for the epoxy to flow thru for a nice bond............you'll just need to drill them
        • m4a1usr
          Fast Electric Addict
          • 2038
          I saw those Aussie made mounts and considered how to attach them myself. My initial idea was to rough up the inside edge and use what ever angle adapter that would fit. Could be something flexible like carbon fiber or just a section of thick FG. In in a flat bottom hydro/ cat it wouldnt involve angle adaption material. The rails look thick enough to use small screws so if your good with sheet metal bending it would be a snap. Those mounts are very well priced!
          John
          Change is the one Constant
          • detox
            • Jun 2008
            • 2318
            I would drill holes then scuff with course 60 grit paper. I good strong and flexible epoxy is a must. I like the cheaper priced RAKA 350 hardener and 127 resin thickened with fumed silica for strong mounting. This same epoxy "unthickened" makes a verygood finishing and building epoxy also. Thickened with Microballoons makes a easy to sand filler. Takes atleast 24hrs to cure and about 3 days for full cure.
            Measure using the Great Plains epoxy mixing cups #GPMR8056
            Boat safety is in the quality. Visit the website of Raka Inc. We take pride in our boat building epoxy products that we deliver from Fort Pierce, FL.
            • Chuck E Cheese
              • May 2008
              • 1684
              ok, thanks...... i will toss around all that advice and see what sticks!
              • drwayne
                • May 2008
                • 2981
                Gday
                Joe and www.RCBOATBITZ.com.au are 20min drive from my desk.
                He had his Co name cut out to use those openings for epoxy
                He's chuffed you think that is good bling !
                Assembling a 56" CF Genesis for him next week.
                Exact same hull as FC Daytona60.. same molds in same TFL factory.!
                For 900US these arrive 'bling complete' with good spec hardware (arneson drives+1/4-3/16 flex, rudder, eng mounts, batt trays, pickups etc ), Gel + genesis decal sets.. needs a few bolts and elec's and away it goes.
                Look for a 'quick' build thread here soon 2x 5692/730Kv on 12S.
                Great to find an FE store just around the corner. :happy:
                W
