You will be that much slower than the Spartan, if its the current Spartan it has a castle 1800kv on 6s which gives 40,000 rpm unloaded. Your 1300kv motor is to low on kv for 6s only giving around 29,000rpm unloaded.
genesis single struggling with speed help me out
im thinking the same so the only solution is a huge prop or different motor right or more cells which i dont want to do
also all that rpm isnt that good either the spartans are cooking the wire drive and crapComment
The Spartans had bad motors in the originals but were 1600kv about right for 6s, they then went to Castle motors & also upped the kv to 1800kv. Cant understand why they went that high on kv ecsecially on a rtr boat. With all the disscutions that went on this forum with Spartans Traxxas still didnt listen to some pretty experience fast electric boaters.Comment
thats an easy answer its because this way its fast out of the box pretty much with some cooling mods and traxxas dont care if you break parts thats why they sell replacement parts its a business and at the end of the day the spartan is extremely fast rtr and in my opinion a good boat for the money using good quality electronics and faster than my genesis but thats because of my inexperienceThe Spartans had bad motors in the originals but were 1600kv about right for 6s, they then went to Castle motors & also upped the kv to 1800kv. Cant understand why they went that high on kv ecsecially on a rtr boat. With all the disscutions that went on this forum with Spartans Traxxas still didnt listen to some pretty experience fast electric boaters.Comment
Selling replacment parts wasnt strictly true as Traxxas were relacing most of the burnt esc & motors under warranty, any one that would have to pay for relacment parts certainly didnt buy Traxxas motors or esc. They relaced them with motors & esc like the Leopard 4082 - 1600kv & the Seaking or T180esc.Comment
Obviously those 6S packs are two 3S packs in series (end to end) looking at the length of them. They would fit easily but a regular 6S pack may be too "fat" to fit in there. Look at the dimensions of the packs on the Hobbyking website and do the math.ok guys im playing with my first rc boat all my buddies bought spartans but i wanted a cat so ive bought the genesis
heres my setup
tacon 3674 1300kv
skywing (6s) 200a esc 200a contnous 220a burst
running 2x6s long pack parralel 25-35c 5000mah
i tried these two props
tr-42-29-15 is 42 divided by 29 = 1.44 (pitch ratio)
42mm or 1.65" x 1.44 = 2.37"
tr-43-26-9 would be
43mm or 1.69" x 1.65 = 2.78"
(as long as my calculations are right)
i know the plastic props are crap i broke couple of them in one day but its for testing when i get it right ill buy 2-3 metal props
the balance is set to 13.25" from the far back of the hull and there wasnt much of a rooster tail no hopping nice and steady i thought it could have had more rooster but the drive is all the way up can go higher without notching the opening after 10min everything was cool to touch
heres the problem my friends with spartans on 6s just fly by me if i had to guess 5-8mph faster when i use the speed calc on OSE it shows that id have to go to a huge prop to run 50+ like an m645,x648
in that range
let me know where you think the proplem is i think i either need more prop or more kv motor to keep up with them or more cells but i want to stay 6s since i bought two sets of them and the esc is 6s at best lol
thanks matt
[ATTACH=CONFIG]73999[/ATTACH]Mini Cat Racing USA
