soldering
  • saleens7
    • 1108
    soldering
    i bought a soldering iron (that coldheat one) and im practicing soldering on some scrap 12 gauge wire...ony problem is i can only get it to solder a small amout of solder or not any at all. when the tip is heated, i can apply solder directly to the tip and it wont melt. Im thinking of just getting a regular soldering iron that actually has continuous heat. but could anyone think of what i might be doing wrong with the cold heat? (it only heats the tip when it touches wire and i can apply solder to the tip when it is heated and it wont melt..
  • Diegoboy
    • Mar 2007
    • 7244
    That iron isn't hot enough to do any "real soldering" It's okay for tinning wire (thin wire), but that's about it. If you have a large trace or surface area, it'll never get hot enough.
    • SJFE
      • 4735
      I'm not trying to be a smart ass or any thing but what ya did wrong was get that thing. I saw it on tv also and rushed right out and got one. Mine shorted and caught fire. IMO they are junk. Take it back if you can. My advice if you are going to solder all the time is to buy a difital 100+ watt soldering station. I use that and a 200 watt gun. When I have the money I will by a Metcal system like Mr Hill uses @ BattlePack. Truth is it's tuff to buy a good system over the counter. The best thing you can do is remember to heat the work...don't use the solder.
      • SJFE
        • 4735
        If you have 4 or 5 hundred dollars here ya go. Systems start @ 199. http://www.hmcelectronics.com/
        • SweetZ28
          • 1322
          That solder gun is a junk i have 2 of them they are only good for emergancy solder jobs with like really thin wires like the size they use on the servos.
          you need a way hotter solder gun for soldering anything normal.
          WWW.PPRSLOTS.COM
          • Diegoboy
            • Mar 2007
            • 7244
            Here's the model I use, and I'm very happy with it.
            Tenma 21-147
            • Doozie870
              • 828
              coldheat = junk
              • Steven Vaccaro
                • 8723
                I had the same problem with the cold heat. JUNK. The only good part was the wire stripper. I was happy until I found out the stripper retails for $1.00
                • Rex R
                  • 992
                  weller 25w iron for the small to medium small jobs (14g wire & deans), weller 80w iron for somewhat larger jobs (12-10g wire & cells), assorted torches for larger stuff.
                  • JimClark
                    • 5907
                    Weller 40 watt works well also but be sure you have at least a 1/4 inch tip but the 80 watt is very good.
                    Jim
                    Billy Graham
                    • saleens7
                      • 1108
                      well, i returned the coldheat and got a weller solder gun (100-140 watts) this thing will melt solder like theres no tomorrow, i tested it on the same scrap wire and this thing works great.
                      • JimClark
                        • 5907
                        dont use that on batteries you want an iron for that
                        Billy Graham
                        • saleens7
                          • 1108
                          its for soldering wires to connectors...
                          • SweetZ28
                            • 1322
                            I have really good silver solder on my site if anyone needs any it's like the best silver solder you can get for low electrical loss when you solder stuff together
                            Melts at 421Deg
                            http://www.pprslots.com/mods.htm
                            WWW.PPRSLOTS.COM
                            • saleens7
                              • 1108
                              i have some rosin-core solder, will that be good?
