motor suggestions
  • camarohrod
    • Mar 2012
    • 64
    motor suggestions
    i have a 40" genesis cat, 200a swordfish esc, 435 prop, what motor would yall suggest for some decent speed(50ish mph), i can change the prop if needed just want to get a better motor than the stock 2075 that came with the boat.
  • BW won
    • Mar 2012
    • 160
    Hey camarohrod,
    I don't know what size motor you need, or feel qualified enough to suggest one. However, this site has a pretty useful tool- the Speed Calc. ( http://www.offshoreelectrics.com/conversion.htm ). Also, there are charts on fighterecat's website, if you join, under resources.
      • 7673
      What kind of price range are you hoping for and what do you have for batteries.
      • camarohrod
        • Mar 2012
        • 64
        i have 4s 5000mah 45c zippys, i was thinkin about upgrading to 6s also
        • camarohrod
          • Mar 2012
          • 64
          id like to get one that will fit into my motor mounts, im not sure the size of my motor now but here is a pic, and i was lookin to spend around 90ish if that will get me a good motor.
          • m4a1usr
            Fast Electric Addict
            • 2038
            Are you sure the prop you have is a 435? As in an Octura X435? Maybe since I dont know some other numerical designation its not what I think. But a 40" hull using a 35mm prop? I'm thinking your off by quite a bit. Another question. Is that a 36mm motor? And is the kv 2075? 4S is not too bad. 6S? Oooch. 6S on a 2075 kv motor even with a small prop. 35mm will not get you 50mph.
            John
            Change is the one Constant
            • h2o 1
              • Sep 2011
              • 770
              That is a stock Genesis 36/74 2075kv motor.I agree with John,if that is a x435 octura,that prop is definetly to small for the Genesis
              • dana
                Banned
                • Mar 2010
                • 3573
                I think I've seen guys using leopard 4082 motors with success in those
                • Make-a-Wake
                  FE Rules!
                  • 5557
                  How about $88ish?
                  4 pole, much higher efficiency, and will fit right into your stock mount. The 1900 or 2200kv are what you need for 4s and the 1400kv for 6s
                  http://www.offshoreelectrics.com/pro...o-3674&cat=148
                  • h2o 1
                    • Sep 2011
                    • 770
                    Thats the set-up i have.4082/2200kv leo and a 200 amp swordfish.I will be running two 4s 45-90c 5000mah in parallel.I will be using an Octura 442 for starters.I haven't taken this boat on its maiden yet,so i have no idea of speed or temps.I have too many projects going on!!
                    • camarohrod
                      • Mar 2012
                      • 64
                      what prop do yall suggest if that 435 is too small with that 4082/2200 kv motor?
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        m445
                        • camarohrod
                          • Mar 2012
                          • 64
                          John
                          i wana upgrade basically all the electronics in my boat, i have ordered a 200a esc and i can change my prop no problem just wana know what i need to go with. im new to boats so i have no clue about all this stuff yet, i have loved the water and live on a river plenty big enough to play on so i want a good setup and my neighbor is about to get into this also. what do you think i will get out of the stock motor with that 200a esc and that prop? will it hurt the esc if i run it like that for a little while or do i need to go ahead and order a motor and prop? the prop says TFL 435 it so im guessing thats the size of it.
                          • h2o 1
                            • Sep 2011
                            • 770
                            Make a Wake, do you have any idea of the speeds that could be reached with that set-up with the prop you suggested?
                            • Make-a-Wake
                              FE Rules!
                              • 5557
                              Which setup? He asked for a motor that would fit right into his mount so I posted the 3674 Leopard..........but now folks are talking 4082's................the 4082 on 4s with an m445 will see 50+ mph...........
