GTX from Heiko
  • FOSSILE
    • Aug 2011
    • 19
    building in progress
    • FOSSILE
      • Aug 2011
      • 19
      working in progress
      now I'm concentrate to redraw the exact design
      • FOSSILE
        • Aug 2011
        • 19
        After many hours, I'm close to the end
        • jkr
          FE Addiction
          • 568
          It came out very nice!
          What sticker is it?
          • FOSSILE
            • Aug 2011
            • 19
            I drew the design on Illustrator and printed on vinyl sticker
            • Fella1340
              • May 2013
              • 1035
              Looks very nice, have you hit the water with it yet? I would love see a video and hear about how things went. Impressive graphics and printed at home, awesome. This turned out good once you got over the fact nobody had what you were looking for. Asking nicely for help gets results to.
              • FOSSILE
                • Aug 2011
                • 19
                Not yet
                I must varnish the hull first.
                  • 7673
                  #23
                  What size is this hull? I like the look of it. Good job on the graphics.
                  • FOSSILE
                    • Aug 2011
                    • 19
                    #24
                    around 32'
                      • 7673
                      #25
                      Are those the props you will be running or something a tad smaller?
                      • FOSSILE
                        • Aug 2011
                        • 19
                        #26
                        I will start with those one, it's k40 and k40L.
                        the max prop diameter will be 42mm
                          • 7673
                          #27
                          May I make a suggestion?
                          • FOSSILE
                            • Aug 2011
                            • 19
                            #28
                            For sure, I'm always open to suggestion
                              • 7673
                              #29
                              I would shorten those stingers,and extend the rudder. As is when you turn rudder you will load on prop while unloading the other. The forces(or lack of) from the props will want to steer the boat the opposite direction that you are intending for the rudder. Not to mention the huge load on one ESC and very little on the other.
                              Rudder should not disrupt water flow to the props simply put. The rudder should be behind the props
                              • FOSSILE
                                • Aug 2011
                                • 19
                                #30
                                My English is not good but I think I understand the most important.
                                Before trying with the rudder (is the safety solution) I want to test with a V-Mixer, what do you think ?
