Extending ESC wires to the RX
  • BHChieftain
    Fast Electric Addict
    • 1969
    Probably a stupid question but I thought I'd ask...
    I'd like to extend the wire between the ESC and the RX using an extenstion harness (which is typically used to extend the Servo wire to the RX). I know extending the actual wires between the ESC and the motor is a no-no, but I would think extending the signal/BEC wire to the RX would not pose any problems...
    Chief
  • properchopper
    • 6968
    I've done this numerous times with no ill effects. Squirt some Corrosion-X into the extension joint to keep connection from corroding if it gets wet. That HAS happened to me and was tricky to track down.
    • BHChieftain
      • 1969
      Thanks sir.
      Chief
      • blizard05
        • Jun 2007
        • 576
        I like to use dielectric grease,and heat shrink tubing
        America home of the free, thanks to the brave [/url]
