What motor in a 42" Mono??? (DF MKII
  • Drax21
    • Jul 2011
    • 1021
    What motor would you put in a 42" Mono??. I have a Delta Force MKII coming in the post.
    Also what esc with the motor?
    Thanks
    Everything that has a beginning, has an End
  • Drax21
    • Jul 2011
    • 1021
    Currently I'm thinking
    http://www.hobbyking.com/hobbyking/s...or_1320kv.html
    with a
    Aquastar 240.
    This is a 8s set up correct?
    • martin
      • 2887
      That motor is to high kv for 8s for a motor & boat of this size giving over 39000rpm unloaded. id look for something around 1000kv on 8s.
      • Make-a-Wake
        FE Rules!
        • 5557
        Thats a 6s motor but will certainly do the job well!!
        This motor would rock on 8s and is plenty big.......... http://www.hobbyking.com/hobbyking/s...or_1050kv.html
        • Drax21
          • Jul 2011
          • 1021
          6s would probably suit me better. Keep costs a little lower as I need new batts as well.
          I haven't used one before but I think I will need a spark eliminator, definitely if I go 8s. Kintec has a few.
          Would I get better run time on a 6s or 8s set-up?
          I have a load of 3/16 cable but 8 to 3/16 seems a bit too big a difference.
          Should I go up to 4mm cable on this one?
          thanks
          • Make-a-Wake
            FE Rules!
            • 5557
            That hull is borderline 6s/8s to me.........................
            3/16 setup should work, I thought you intended to run 8s?
            • Drax21
              • Jul 2011
              • 1021
              What do you mean borderline 6/8s??
              What battery configuration do you suggest for 8s?
              • Make-a-Wake
                FE Rules!
                • 5557
                I mean that a 42" boat is on the edge of being either a 6s or 8s boat. Run 8s2p, four 4s batts, two in series then paralleled to another set.
                • Drax21
                  • Jul 2011
                  • 1021
                  Ah ok got ya, and what mah batts should I look for?
                  I currently only have 4s 4200mah batteries
                  • Drax21
                    • Jul 2011
                    • 1021
                    I'm thinking Haiyin 5000mah 40c
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1837
                      Even a Leo 4082/1600 on 6s2p will get you around 90-95km/h with a 448 prop. it's not bad.
                      Visit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
                      "Follow someone's footsteps and you will always be a step behind"
                      • coolmind
                        • Oct 2010
                        • 46
                        I have the same setup(turnigy 5690 1320kv-aquastar 240hv-6s5800 zippy lightmax X2 parallel)on a 45 cardiff.The prop is the prather 240(53,8mm and 1,55 pitch).
                        And i can play for around 20 minutes!!!!!!!Highly recomended setup.Otherwise you can go for a T600 outrunner 1400kv and prop around 47 but it is smoother than the 5692 monster!!!!
                        • Drax21
                          • Jul 2011
                          • 1021
                          http://www.youtube.com/watch?v=xnkGl...1&feature=plcp
                          The link didn't work can you post it again please. What is the top speed in your 45" ?
                          • coolmind
                            • Oct 2010
                            • 46
                            Sorry about the link.this is the working one.I dont know about the top speed because it is the first test run i deed with the boat last sunday.But from what i see 65 to 70.
                            http://www.youtube.com/watch?v=xnkGl1gNV6s">http://www.youtube.com/watch?v=xnkGl1gNV6s" type="application/x-shockwave-flash" width="425" height="350">
                            • lenny
                              • Sep 2010
                              • 4294
                              Looking good my friend Nasos,
                              Do you still have the 40"cigarette with the t600 1400kv setup ?
                              ? ONLY IF THEY WORK
