Need suggestion for Pursuit motor
  • tlandauer
    • 5666
    Got a Pursuit from a Forum member,boat is new, I think the motor is Leo 4082, 2200Kv. Anyway, when I twist the prop, the cogging is a bit uneven, most notches are crisp, there are just one or two seemed to be a bit un-articulated. I have the same motor in my Miss Geico, it seems to run stronger/faster ( both use 4s set-up)
    Question: should I get a new motor, and if yes, I like Leo 4082, but which Kv, 2000 or 2200?
    The boat runs like it's on rails, very stable, but with x442 and x640 ( only props I have at the moment) , it is only at 38.3mph---a bit slow, it is not running too wet either. Temp. is cool, no problems there.
  • jamespl
    • 742
    Why not take the motor out of your geico and try it in the pursuit first. That should tell you if the motors shot.
    http://inlinethumb55.webshots.com/32...600x600Q85.jpg
    http://inlinethumb04.webshots.com/45...600x600Q85.jpg
    • tlandauer
      • 5666
      Thought of doing that, the only thing is motor mount has been modified and taking it out now might mean a rebuild, was just thinking out loud. Thanks for the suggestion though.
      • Make-a-Wake
        FE Rules!
        • 5557
        So you are only hittin' 38 mph with a Leopard 4082 2200kv on 4s????????? I'm getting low 50's out of mine which is the same setup using an m445. I do run 2p however, the 4082 sucks amps, if you dont supply them it will suffer.
        • Basstronics
          • Jun 2008
          • 2345
          Im going to be running a 4074 with an m445 and a t180
          • Make-a-Wake
            FE Rules!
            • 5557
            You'll get high 40's...................i used to run that, good setup!!
            • Basstronics
              • Jun 2008
              • 2345
              Sweet. I cant wait to get the boat in the water. Heading out for paint this weekend.
              • Make-a-Wake
                FE Rules!
                • 5557
                Make sure you dont skimp on the batts...........5000mah and 40c minimum!!!!
                • Basstronics
                  • Jun 2008
                  • 2345
                  Thanks for the info. I gotta still tie the motor mount down and everything else internally. I almost bought some 4000 packs. Glad I didnt now.
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    The Leopard 4074 seems to be more effiecient than the 4082.................there's a big jump in amp draw up to the 4082 2200kv. But, the 4074 still needs the juice, 40c and 5000mah give you 200amps constant availability to feed the motor. I run 2p with my 4082 cuz 1p just doesnt get it done.................I run two 4s 45c 4000's in parallel, which equates to 4s 8000mah at 360amps constant.
                    • tlandauer
                      • 5666
                      I plan to run 4s parallel, but was going to order 5000mah. If you are running 4000mah at 360 amps constant, would that be too much ( 5000mah, 40 C ) for the 180A Seaking ESC?
                      Since the mount is a modified one, its length is only good for a 4082. But it's good to know the 4074 is a bit more efficient, thanks !
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        The batts and ESC only provide what the motor asks for.......................best to have more amps available than not enough which leads to blown ESC's and bloated lipos.
                        • tlandauer
                          • 5666
                          Thanks, understood.
