Vegetable oil?
Just for good measure, I would put a piece of fuel tubing on the stuffing tube between the motor collet to act as a seal. Water tends to travel up the stuffing tube while running. This is a result of the flex "carrying" the water up. Plenty of seasoned boaters here will tell you the same.Government Moto:
"Why fix it? Blame someone else for breaking it."Comment
The oiler is done and so is the boat. Here is the link to my build http://forums.offshoreelectrics.com/...d-aka-Fountain
So far I have tired peanut oil as I have heard it can with stand higher temps, not that I plan on having my flex get hot at all. It is a pretty thin oil and showed me where I have a few leaks, one is the flex inside the hull (which I will use a piece of fuel tubing) and the other is the seal that holds the stuffing tube. Not a big deal just have to get time to do it. Other than that is works out good so far....more to come
Image0581.jpg24 R/C vehicles and still counting...What budget?Comment
[ATTACH=CONFIG]74073[/ATTACH]
That oil reservoir looks amazing. Where did you buy it from? GREAT build!Comment
Rather than the relatively thin oils mentioned above, I prefer good quality marine grease. It is also less likely to allow water to wick up the stuffing tube & cause leaks. JIMJIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract SpecialistComment
Thanks Vortech! I did not buy this reservoir though, I machined it out of 3/4" round 7075 T651 aircraft aluminum. Took a bit of time but it came out pretty good. I also wrote a program for the punch press I run to punch out the carbon fiber pieces you see on the reservoir.24 R/C vehicles and still counting...What budget?Comment
I took apart my boat for paint and I noticed the gum-up that some have mentioned with these types of oils. I think I need a thicker oil compared to peanut oil. I am going to try the chain saw bar lube next and see how it goes....24 R/C vehicles and still counting...What budget?Comment
