small gps units?
  • steveo
    • 1454
    small gps units?
    all right i have a garmin etrex which is great in larger boats but putting it in my vac u pickle......not gonna happen, is there a unit that just does everything but track my location, just speed time etc...
  • Drax21
    • Jul 2011
    • 1021
    garmin gecko or forerunner are smaller. I use a gecko in my 32" cat as the etrex is too big.
    Everything that has a beginning, has an End
    • Anbjorn
      • Apr 2009
      • 248
      Here you go:
      I have one and it works quite well.
      Anbjørn
      • Snowride
        • Sep 2010
        • 297
        I have a Holux 245 which is almost 1" shorter than the Garmin gecko. Maybe this will fit? http://www.ebay.com/itm/Holux-GR-245...ht_3817wt_1180
        • siberianhusky
          • Dec 2009
          • 2187
          GPS module for an eagletree? Get the advantages of the eagletree data logging plus the gps.
          Might cost a little bit more up front but you do get 100x the info out of it.
          GPS will only tell you speed, the eagletree will tell you what you really need to know, amps, volts, rpm and temps + speed with the gps.
          Plus the eagletree is about the size of an esc.
          • steveo
            • 1454
            Originally posted by Anbjorn
            this is right up my alley, but i am also going to look into the eagle tree i did not know it will record speed as well . thanks to all that replied
            • HydroMike
              • Oct 2011
              • 334
              That's what I'm thinking of going with is the eagle tree a lot more information plus be better in the long run
              • alvinm
                • Feb 2012
                • 77
                I'm also a cyclist, so I use my Garmin Edge 800, which is really small. Downside, its $400 for the basic model..
                • sailr
                  • Nov 2007
                  • 6927
                  The pic shows it only goes to about 80kph which is only 49.7mph! Not sure if it does more but that's a big limitation if it doesn't.
                  Mini Cat Racing USA
                  www.minicatracingusa.com
                  • sailr
                    • Nov 2007
                    • 6927
                    I downloaded the manual and it appears the speed is not limited.
                    Mini Cat Racing USA
                    • Snowride
                      • Sep 2010
                      • 297
                      There are several modes and the 80km is because it is set in Bicycle mode. If you set to car mode to will change the scale to 199kph or mph if you prefer using Amercan units. It real is a nice unit by the way.
                      • numse1964
                        • Oct 2010
                        • 37
                        Hi
                        Will these GPS work out of the box in a carbon/Kevlar hull ?
                        Best regards Henrik
                        • jcald2000
                          • May 2008
                          • 774
                          No, Carbon fiber blocks the signal. Thats why the radio ant. must go out side so must the GPS or get one that has an external ant. option.
                          • numse1964
                            • Oct 2010
                            • 37
                            Hi jcald2000
                            Thank you for the info :-)
                            I will start looking after that type of GPS.
                            Best regards. Henrik
                            • electric
                              • May 2008
                              • 1744
                              Thought I would add another option to this thread. I just bought one of these for 129.00 and free shipping. It is waterproof and you just take the band off and put some velcro on the back(I recall I just cut the band off the old one). Runs on "AAA" batteries. I had the Forerunner 101 for a long time until it went down to Davy Jones Locker when I lost a hatch. Really easy to use and just toss it in and you are good to go. Here are the dimensions:
                              3.26" x 1.71" x 0.7"
                              As you can see, nice and thin and not too long either. You might find an older model(used) for the sub $100.00 range.
                              http://www.amazon.com/Garmin-Foretre...forerunner+301
