Is an inline rudder faster than an offset rudder?
A rudder that is not fighting itself to keep hull tracking strait is a fast rudder. For perfect rudder adjustment set rudder dead strait in line with centerline of hull (offset or inline rudder). Then remove turnfin and run the boat (accelerated quickly)then check to make sure boat is tracking strait. If not bend or shim your strut until hull tracks strait. Once strut is set do the same for turnfin making sure rudder is dead strait. You may have to bend or shim turnfin bracket to get hull to track strait.Comment
Now that we've breached the phenomenon of "prop walk", consider the role the rudder can play in compensating for it and thereby increasing your top speed. The amount of rudder area in the water is the only thing keeping the prop from walking the transom to the left and steering the boat to the right. Therefore a wide and/or deep rudder is a good thing, because if you have to hold any amount of left rudder to keep your SAW boat going straight through the timing lights you'll notice that kills the speed. It's another balancing act. The rudder is a major source of drag to a boat going fast. You want to have enough rudder in the water to counteract the prop walk, but not too much. Keep the rudder thin and wide, and just deep enough in the water to cause the boat going straight ahead.Comment
PS: I was running a strudder on my 56" Segad. It was squirely as hell. www.youtube.com/watch?v=IPZGtssIXyQ Gonna put an offset on it & test it in a few weeks. Let you know how that goes.Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco PowerComment
