I am running a Genesis which I have fitted out with a Leopard 4082 1550Kv with M445 prop, 6S batteries, and T180 ESC. (My first Offshore Electric Racing boat, so I'm still very much on a steep learning curve). It seems to be going pretty well. I am getting 60 mph (97 kmph) and it seems quite stable at full speed -runs flat and level. But it does some porpoising while it is accelerating and also in turns - not real bad, but I'd like to eliminate it, before I move up a prop size to a M545. I also get quite a large rooster tail of spray, but I don't really know what to expect in this regard.
COG is at 0.33 I have the strut height set so that when the hull sits on a flat table, the bottom of the strut is also just sitting on the table, and it is angled slightly i.e. angled in the direction such that the prop end of the strut is slightly higher than the end where the flex cable goes in.
Seems to me that the 3 variables that may cause or prevent porpoising would be COG, strut height or propshaft angle. I am happy to play with these in turn and try them, but I would like to know what effect I could likely expect to see from changing each of them? I am guessing that there may be quite some interaction between them which could make it tricky to find the ideal settings for each one. So any pointers would be really appreciated.
Cheers,
Jon
Cheers,
Jon
