3/16 flex questions.
  • floatn turd
    • Oct 2011
    • 267
    I'm converting my .150 system in my MC to the 3/16.
    Question 1) There is not "flat-spot" on the shaft for the drive dog nut. (hex screw) Is it a "have to" as far as having one? If I do have to have one how do I make it??
    Question 2) Should I run the 3/16 with no Teflon liner in the 1/4 brass tube and strut thats already there? OR should I buy a new strut and go thru all that business of bending and installing a new 3/16 brass tube to match my new 3/16 shaft??
    Thanks for the help.
    Mr.T
  • Gimp
    I am the Stig
    • Jan 2011
    • 547
    Use a small file to make a flat spot. You'll need a 1/4" tube for .187 flex without liner.
    -Fighter Cat Racing-
    • floatn turd
      • Oct 2011
      • 267
      your right, I meant 1/4", I changed my post. But thats what I have. (1/4) What would you do? run it without? (I'm good about maintenance and grease) or swap it all out, to make everything 3/16?
      and thanks for the info on the flat spot. Is there a measurement on where to make the "file" mark?
      thanks
      • Boaterguy
        • 1760
        hook the whole system up and put the drive dog on, when you tighten it it should make a small mark on the shaft, that is where you file away.
        • Gimp
          I am the Stig
          • Jan 2011
          • 547
          thanks
          Yea use 1/4" tube for .187 with NO liner. The liner does nothing but cause issues.
          • floatn turd
            • Oct 2011
            • 267
            Perfect, Both of you have answered all my questions on the subject.
            Thank you for the info.
            I'm now off to the bar, so I can work on my boat tomorrow with a sweet hang over and maybe wake up with a "random"
            thanks again
            Mr.Turd
            • Gimp
              I am the Stig
              • Jan 2011
              • 547
              lol, good luck I guess
