34inch fightercat cheetah 4092leopard 1300kv on 8s lipo this will get me between 70 and 75 mph im hoping what do you think. I have not been able to find any videos of this boat running. Does anyone know of any vids.
looking to achieve 70 to 75mph
Tags: None
There is a gent on here that reached 80mph+ with i believe to be a 4082 on 8 or 9s in a similar sized boatNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
If you want to go 70-75 MPH and can afford to loose the boat - go for it. I think you would be better off with a larger cat that won't be wasted in a crash at that speed. i.e. Aeromarine Avenger Pro. JIMhttp://www.aeromarinerc.com/index.ph...id=40&Itemid=1
JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract SpecialistComment
just go 60 in an oval with that hull..the wide tunnel will probably make it want to fly but who knows for sure until its done..the hpr's and others like the genesis hull are better canidates for high speed passes in a straight line due to the smaller tunnel but will not fair as well as your cheetah as far as turning goes..i am doing a fightercat shocker hoping for 80 myself but is has a thin tunnel section more suited to do so"FE" STANDS FOR FRUSTRATING EXPLOSIONSComment
Do you still have the twin sprintcat?
OP:
It's really hard to know at this point what the Cheetah will like. A lot of the European guys run in the RPM range you're at with a smaller prop, but they run cats with a relatively narrow tunnel and twin props. The Cheetah will likely be able to handle a decent sized prop, so you might not have to spin it that fast.Comment
I agree any cash above 65 -70 does some damage IMO I hade some crashes at 62 mph that did some decent damage with the hull being reinforced it all depends how the hull hits the water thanks
Chrismy youtube videos http://www.youtube.com/user/chris81983?feature=mheeComment
I agree any cash above 65 -70 does some damage IMO I hade some crashes at 62 mph that did some decent damage with the hull being reinforced it all defends how the hull hits the water thanks Chrismy youtube videos http://www.youtube.com/user/chris81983?feature=mheeComment
What strut and rudder are you going to use on your Cheetah
I'm building one now 4082 1610kvv or 4092 1600kv 6s single
The 32 FC mono stingers didn't fit to go twin drive, so changed to a single setup
Now im stuck with not nowing what hardwear that will fit is has a very high transomFC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
Popeye Hydro T600 1400kv 6s1pComment
