Stuffing tube for wire drive
  • Tom Costello
    • 44
    What is the optimum ID for the stuffing tube in which to run .078 wire drive? This will be in a Whiplash 20 and the curvature will be minimal.
    Thanks
  • Darin Jordan
    • 8335
    Tom,
    Were you going to be running teflon, or not??
    Darin E. Jordan - Renton, WA
    • Tom Costello
      • 44
      No teflon, brass tube only.
      • Darin Jordan
        • 8335
        I believe I've been using 1/8" O.D. With a .014" wall thickness, that makes for a .097" ID...
        When I do brass only, however, I don't run it the full length... just through the hull, and I leave the wire exposed back to the strut.
        On my 1/10th Scale, I run it all the way back, but I use larger tubing and teflon.
        • Boaterguy
          • 1760
          I was told 5/32" O.D. K&S (again .014 walls) and that's what i have on mine, I have never run it though.
          • Jeff Wohlt
            • Jan 2008
            • 2716
            1/8" could be a little small. I think I said 5/32 which gives you an 1/8" ID. Run it all the way up from strut to coupler.
            www.rcraceboat.com
            [email protected]
