Which GPS do you use?
  • z400
    • 1311
    I will be buying a hand held GPS real soon to do testing and such with my boat.
    Just was curious on what everyone has GPS wise.
    pictures and links more then welcome
    Thanks
    Z
    KBB34" Mono - Fast
    ToySport Triton- Not as fast
  • Bill-SOCAL
    • Nov 2007
    • 1404
    I use the Garmin Forerunner 101. Small, light, reliable.
    I take the wrist strap off and use Velcro to hold it inside the hull.
    $85 on Amazon.com
    http://www.amazon.com/Garmin-Forerun.../dp/B0001ILXGQ
    The Garmin eTrex is popular (it is the yellow one you see) but it is HUGE compared to the Forerunner.
    Don't get me started
    • GregS
      • 82
      There is also the Garmin Geko 101 and 201 which is much smaller than the Etrex. The 101 is the cheaper of the two but has been discontinued. However you may be able to find a used one on ebay for a good price.
      Greg
      • z400
        • 1311
        Thanks to the both of you!
        i appreciate the replies
        i was looking at the Etrex and a few other models that were similar.
        i kept over looking the Forerunner, but hey if the Forerunner works..
        i love its size!
        Z
        KBB34" Mono - Fast
        • DeWalt 1/8th
          • Jan 2008
          • 19
          The Garmin eTrex is a good one.
          That is what i use.
          If your buying Garmin make sure it is WAAS-enabled for the best accuracy (the eTrex is ), unfortunatly just a bit heavier and more bulky than others.
          • Ub Hauled
            • Aug 2007
            • 3031
            The forerunner is cheap as well... I use it too.
            • blakybob
              • 126
              I've been using the eTrex H also. Like DeWalt1/8 was saying, be sure to get the WAAS enabled one. Fast signal aquisition and keeps it. I bought the forerunner 101 first and took it back. It took a long to aquire and it lost the signal ALOT. I tried it all over the United States with the same result. I may have just had a bad one though. Here's a link for the eTrex H. Happy shopping.
              Blake
              • z400
                • 1311
                How much exactly does the eTrex H weight in at?
                Z
                KBB34" Mono - Fast
                • Bill-SOCAL
                  • Nov 2007
                  • 1404
                  eTrex = 5.3 oz
                  4.4" x 2.0" x 1.2" (11.2 x 5.1 x 3.0 cm)
                  Forerunner 101 = 2.6 oz
                  3.26" x 1.71" x 0.91" (8.28 x 4.35 x 2.3 cm)
                  And some info on WAAS:
                  • robby76
                    • 190
                    i was using the garmin etrex. very nice unit. a little heavy. found a small one that straps onto your arm and gives you the time, mph, avg mph, max mph, time running, distance, & if you use it for actually running or walking, how many calories you burned, and you can set a course on it and will give you how many laps.
                    it is a triangle and waterproof and i put it in a sandwich bag and made a place for it inside the hull in a styrofoam compartment.
                    R300 GPS Sport Tool for running by NAVMAN. it sells for $140 but was on sale for $40 new. uses 1 AA bat.
                    • z400
                      • 1311
                      Originally posted by robby76
                      i was using the garmin etrex. very nice unit. a little heavy. found a small one that straps onto your arm and gives you the time, mph, avg mph, max mph, time runnig, distance, & if you use it for actually running or walking, how many calories you burned, and you can set a course on it and will give you how many laps.
                      it is a trinangle and water proof and i put it in a sandwitch bag and made a place for it inside the hull in a styrofoam compartment.
                      What is it called?
                      am unsure if you stated that or not
                      Z
                      KBB34" Mono - Fast
                      • robby76
                        • 190
                        • z400
                          • 1311
                          weighs roughly 4.something ounces
                          i found one lol
                          Z
                          KBB34" Mono - Fast
                          • robby76
                            • 190
                            i found one lol
                            that's with arm band.
                            i was in need of one and for the price and on hand i bought it. not bad cause i strap it on when Lynda & I go walking.
                            • z400
                              • 1311
                              Sweet
                              i've got a perfect place for it in my SW36, other boat isnt finished being built so who knows where it will go
                              Z
                              KBB34" Mono - Fast
