Scuffing review!!
  • DjFlipNautikz
    • Jan 2012
    • 65
    Scuffing review!!
    Used some 400 grit wet sanding. Is it enough?What u think?
  • DjFlipNautikz
    • Jan 2012
    • 65
    Well heres a video after some strut adjusment and finishing the scuff with 600 grit...i think it helped alot...
    • steveo
      • 1454
      hard to say if the sanding made a difference because you adjusted the strut there is no base reading if you had not adjusted the strut then you maybe see the difference from sanding only
      where are you in florida?
      • DjFlipNautikz
        • Jan 2012
        • 65
        I am in Miami, FL. Yes I know I really can't tell if the scuffing helped because I made 3 different mods: 1) scuffed 2) lowered strut 3) repositioned batteries a little more forward and towards the outside.
        However I am pretty happy with the overall performance of the boat. It has come a log ways. I jut saw a thread someone posted in my other thread to what he did to get it race ready like get the bottom totally flat, which I'm going to take a look and if it needs will do it.
        • jeepme
          • Jun 2011
          • 59
          Once sanding and making the bottom flat do you just leave the bottom or should you clear coat/paint it to protect the sanded finish??
          • longballlumber
            • 3132
            There is no need to paint or clear coat on Fiberglass hulls (only wood)...
            Later,
            Mike
            • Darin Jordan
              • 8335
              You can... don't need to for "protection", unless you sanded through the epoxy layer and have the matt showing through.
              Whatever finish you leave, make sure you ultimately leave that with a 320 or 400-grit sanded finish (longitudinally). A painted surface is "sticky"...
              Darin E. Jordan - Renton, WA
              • DjFlipNautikz
                • Jan 2012
                • 65
                In the pictures above i do not think i sanded through the epoxy layer..
                and i finished with 600 grit should i go back over it with some 400 grit and leave it like that?
                • Darin Jordan
                  • 8335
                  I've always used 400, but other opinions may differ. Try it both ways and let us know...
                  • jeepme
                    • Jun 2011
                    • 59
                    Thanks Darin
                    • steveo
                      • 1454
                      i think the difference in 600 and 400 would be you just sanding for another hour you will not see a any change
                      • Stephavee
                        I like cool things!
                        • Jan 2011
                        • 218
                        If you just leave the hull scufed does help speed? i heard it can help break the water suction....? If it does help how much?
                        " Do you really need anouther boat "
                        YEP!
                        • electric
                          • May 2008
                          • 1744
                          Can I second that question. I get the theory, just not sure if the results are tangible?
                          • jcald2000
                            • May 2008
                            • 774
                            Put a drop of water on a Painted surface, see it beadup in a big fat drop?
                            Now scuff it up with 400, no drops sticking to the surface.
