Permatex bearing and sleeve retainer
  • siberianhusky
    • Dec 2009
    • 2187
    Anybody tried this high strength retainer to assemble a shaft?
    Seems easier to find than Loctite around here although both are available at different places.
  • ray schrauwen
    • 9471
    The Loctite Steve at OSE sells works properly I think it's 630 or something.
    HK sells TL-680 that works very well if in stock.
    680 not 690
    • Jeff Wohlt
      • Jan 2008
      • 2716
      603 but your tolerances have to be very close as it is thin. I pesonally do not like 603....there is better and stronger..
      www.rcraceboat.com
      [email protected]
      • ray schrauwen
        • 9471
        MHZ usa sells the 648 that I think has better gap filling properties.
          • 7673
          MHZ has 648? Darn,I was told Loctite wasn't making it anymore.So I got 638,works like a charm.
          • siberianhusky
            • Dec 2009
            • 2187
            Thanks guys, I was just wondering really about the permatex, I was in 3 different auto parts places trying to find a muffler and they all stocked permatex by the registers.
            Just really wanted to know if it was an alternative as one of the stores is within walking distance.
            I usually buy my shafts pre assembles anyway.
            Cheers and thanks for the replies.
            • Basstronics
              • Jun 2008
              • 2345
              I use 648.
              • Jeff Wohlt
                • Jan 2008
                • 2716
                Yes, permatex is good.
                www.rcraceboat.com
                [email protected]
                • egneg
                  • 4670
                  They are a reputable company that has been around for a long time. I have used many of their products and I am sure this will be just as good.
                  IMPBA 20481S D-12
                  • properchopper
                    • 6968
                    I've used 603 for years on all my .150 cables, never had a shaft/cable seperation. My procedure :
                    Shaft : carb cleaner inside, swirl cue-tip inside & let dry
                    Flex : hit lightly with wire brush ; spray with carb cleaner & paper towel dry
                    (These steps remove any residual machining lube)
                    Fill shaft with 603, assemble & wipe off excess that escapes after insertion
                    Let dry 24 hrs.
                    Note that there's a shelf life disclosure. Kind of gripes me that it expires long before I use hardly any at all.
                    • ezhitz
                      • Aug 2009
                      • 428
                      I have used Loctite 620 retaining compound seems to hold up ok.
                      :canada
