T120 LVC issues
  • jamespl
    • 742
    T120 LVC issues
    The LVC on my T120 seems to be playing up but I'm not sure if it's the esc or the new motor I've installed. The boat is a stiletto and the motor is a turnigy xk3665 2100kv. The boat runs ok for a min or 2 then hits LVC. If you let the boat stand for a few secs you can get full throttle for a good 2 secs, so it's behaving like the batts are dead but I took the same batts put them in my genesis and they worked fine and that's running a T180, 4074 2000kv with an x645 prop. I'm
    A bit hesitant to turn off the LVC on my T120 but want to be sure before I buy a new one.
    http://inlinethumb55.webshots.com/32...600x600Q85.jpg
    http://inlinethumb04.webshots.com/45...600x600Q85.jpg
  • Diesel6401
    Memento Vivere
    • 4204
    Common issue on the seaking esc's. The 180 may or may not start doing the same. Disable the "auto" detect funcitons and manually enter the number of cells you are usinig. Set the LVC for 3.0 or 3.2 (i use 3.2) issue should go away. IF it doesn't you'll have to turn the lvc off completly and run a lipo saver or time your runs. It's the only negative I have found on the seaking esc's and my other (car and plane) hobbywing esc's don't do it so not sure why it's only related to the seakings. Weird.
    - Diesel's Youtube
    - Diesel's Fleet
    • jamespl
      • 742
      I have it set to number of cells and I changed the LVC from 3.2 to 3.0 and it's still playing up. I will try reprogramming it before I turn it off.
