Want your high amp draw ESC to run cooler?
  • Make-a-Wake
    FE Rules!
    • 5557
    Just got a swordfish 200a 6s ESC in from Steven to replace the T180 in my 39" Vader mono, 1717 6s2p.
    These mods are made to allow better amp flow and to reduce the dreaded heat buildup in the ESC and inside the hull
    The T180 tends to LVC prematurely and also has thermalled on me several times in the heat of summer. I have had great performance out of the SF 240hv's so i thought i'd give a 200a a try.
    Firstly the 1717 wires have been cut down from 8" to 3", the SF motor leads are now reduced to 2.5", so total wire length went down from 13" to 5.5"!
    Next i added a small bank of 35v 580uf caps soldered to the batt wires up close to the ESC.
    Then i went with 6.5 bullets from ESC to motor up from 5.5's, and then thought 'why use a parallel adapter with bullets?'
    So............i bypassed that and simply soldered my two leads on each wire which reduces heat and gives better power flow.
    This ESC should be ready now to perform to its top capability and not be strained as much as stock.................BTW, the swordy 200a now has TWO cooling plates as well!!!
    • 7673
    Very good. I do have proof of improvement by shortening the leads.I did it with my Hydra Ice 240 and greatly reduced the voltage ripple.Now I just got to figure out how to retrieve my docs from the logged files.
    • Chrisg81983
      • Jul 2011
      • 1556
      Hi very nice job it does make a noticeable difference shortening wires but. Just got a new sf200 and when I go t program it it says connection timed out and invalid parameters yyyy do u have this problem or did u ever have this happen to u I read another forum member recently had his problem Thanks chris g
      • Make-a-Wake
        FE Rules!
        • 5557
        I use the manual programming board with toggle switches...............works just fine, dont have a pc programmer, no help, sorry.
          • 7673
          I have also been having the occasional issue with the PC.The SW240 I have in my DF won't connect.MY 200's are fine.I have the program box too so just did it that route.
          • thomaslambo
            • Nov 2010
            • 232
            Are you using the Hifei program box?
            When I use any other program box it gives me the same error about timing out.
