new 200 sw esc help
  • CHUD
    • 497
    new 200 sw esc help
    OK buds I got a swordfish esc ,I have set number 1 to 6s,But number 2 is called /brack type/ Now do I set to close or soft brake.
    Now allso number 3/low/middle /high/auto
    number 4, hard cut off/soft cut off
    number 5, soft/standard/fast
    number 6//,PWM/ 8KHz/12KHz/16KHz
    I am running this esc with a keda 1350kv
    two 2p zippy 30c 5000 lipo,s
    tactic 2.4 rx tx
    445 prop in a spartan ,can some one help me out,and do this wright ,
  • lenny
    • Sep 2010
    • 4294
    Hi,
    I have a 120a and I have it set like this on a 9xl on 4s,
    1 on
    2 off
    3 off
    4 on
    5 on
    6 on
    7 off
    8 on
    9 on
    10 off
    11 8KHz on
    12 ON
    ? ONLY IF THEY WORK
    • CHUD
      • 497
      Originally posted by lenny
      Hi,
      1 on
      2 off
      3 off
      4 on
      5 on
      6 on
      7 off
      8 on
      9 on
      10 off
      11 8KHZ
      12 ON
      Lenny so do I just wing it,maybe 1 too 5 ,but whats pwm
      • lenny
        • Sep 2010
        • 4294
        Sorry, #11 That is on for standard motors.
        Not sure on that KD motor.
        8KHz and you should be safe and see how it runs,
        You could move up but your temps may go up to.
        Just check temp at short runs, Like 1 to 3 minutes.
        ? ONLY IF THEY WORK
        • CHUD
          • 497
          No worry's Lenny
          Come on bud 's I need to get this boat in the water tomorrow
          • Boaterguy
            • 1760
            tactic 2.4 rx tx
            brake doesn't matter that much, set it to off
            3= low/middle, play with it or let someone who has run the motor chime in
            4=hard cut off, if you lipo hits low voltage, the motor will stop completely (you will be able to un it again don't worry)
            5=again not a big issue, soft will accelerate the motor slowly, medium will accelerate it more aggresively and so on for hard
            6=8khz, anything else will just create more heat (quoting Ben)
            • CHUD
              • 497
              Thanks bud I will start there, and see how it go's
              • Boaterguy
                • 1760
                start with low timing for now.
                • CHUD
                  • 497
                  Just to ask what is timing advane, and I see there's an //auto//
                  • Boaterguy
                    • 1760
                    I don't really know exactly what it is but heres my educated guess
                    the motor is spinning fast enough that if the coil right above the magnet strikes it won't be very efficient(also dependant on number of poles), but if you set the timing to say 10*, the coil 10* in front of the magnet will strike to get better efficiency
                    again i am not sure this is just a theory
                    • CHUD
                      • 497
                      OK I programed it once and hooked it up it ,beeped really fast only two beeps ,one beep small,and then loud
                      and than I pulled the trigger and nothing
                      So I started all over and the samething
                      So I programed again than moved back to the boat and the same two beep's and nothing
                      Some one got any Idea's
                      • lenny
                        • Sep 2010
                        • 4294
                        Did you calibrate the throttle range of the transmitter when you first used the controller ?
                        ? ONLY IF THEY WORK
                        • CHUD
                          • 497
                          I did not try that ,but I will right now
                          • CHUD
                            • 497
                            I took the rx and tx and put it in the df33 just to make sure it work,and it did
                            Than i put it back in the spartan,and plugged the batts in and two beeps,than I moved the throttle range and nothing,so I flipped the buttin that has /r/and/t/ the motor moved and diden't stop so I pulled thrigger and moved the throttle range up and down,the motor would not stop,but did go up and down when I pulled the trigger,so I unplugged
                            • lenny
                              • Sep 2010
                              • 4294
                              Yes, When I first got mine the thing went nuts to,
                              I had to read the manuals alot of times and you have to be quick with the throttle calibration.
                              The S F is a pain in the ass at first, But it gets easier with time.
                              I was using a tactic tx & rx with mine and think I had to move the switches to.
                              ? ONLY IF THEY WORK
