1800 or 2030?
  • Rob DeAngelis
    • Dec 2011
    • 269
    1800 or 2030?
    Whats the real differance in a 2030 and 1800 kv motor? asking because my motley crew came with a 2030kv instead of the posted 1800kv... Why?
    Lakeside entertainer
  • detox
    • Jun 2008
    • 2318
    More speed. You better swap out those cheap factory motor connectors for some beefier bullets
      I have no idea why your MC had the 2030 Kv motor - was it new? The 2030 motor has the potential for more speed, but to get it you will likely draw more amps. You will need to run a slightly smaller prop with the 2030 motor. In a hydro the 2030 is worth 2-4 mph over the 1800, but in the cat the ultimate difference will be less.
      • Rob DeAngelis
        • Dec 2011
        • 269
        I got it off ebay for a great price... 300 and free shipping... idk i was expecting a 1800 and when i got it, it had a 2030??? whatever im going to run it as is...
        • Rob DeAngelis
          • Dec 2011
          • 269
          Will the "smaller" prop reduce my "out out-of-the-hole" and add to my top-end?
          • Rob DeAngelis
            • Dec 2011
            • 269
            detox, shoot me a link to "better" bullet connectors- I have no idea. my current bullets are gold plated. also, do I have to upgrade the wires?
            • siberianhusky
              • Dec 2009
              • 2187
              Won't be much difference in speed in a MC at all, tried all the spec motors in mine, I prefer the 1500kv Geico motor with a bigger prop.
              Much more to be gained by fixing the imperfections in the hull and getting it set up perfectly.
              • JIM MARCUM
                • Jun 2011
                • 773
                robde ul1, Your 1800 motor will give you 26,640 RPM with 4S (14.8 V). That's OK for fun boating, but you will need a larger prop w/more pitch to make it race worthy. A larger prop will "get out of the hole" quicker & has a higher top end than a smaller prop, but will draw more amps. So go up in prop size slowly & keep an eye on motor heat.
                Bullet connectors get larger as the amp requirements rise. If you have 4.5mm gold bullets & they desolder themselves between the ESC/motor (like I have) go with 6-8mm bullets. Hell, I've had 8mm bullets desolder in running 8S2P SAWs. I don't know what ESC/motor & wire guage you are using so I can't be specific. It's hard, but not impossible to change the ESC & motor wires to flexable 8 guage wires. It will void any warrantee. I'm retired and don't have a lot of money, but my time is worth more than trying to put new wires on the ESC/motor. I'd just buy a new 200-240 Amp HV speed controller.
                As to your $300 ebay motor, I'd ask the seller to exchange your 1800KV motor for the 2030KV as advertized. If they won't, file a complaint with ebay and/or paypal. JIM
                JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
