Hi Guys,
I have always liked watching people race boats around ponds and lakes, and have been an avid RC enthusiast for many years. I decided to span my RC reach to boating as I have all other bases covered.
Here is a list of what I have purchased so far:
HK Genesis cat (semi rtr)
ZIPPY Flightmax 5000mAh 4S1P 20C x2 (bought specifically for this boat)
HK-310 3 Channel 2.4ghz FHSS Ground Radio
Turnigy Aquastar 120A Watercooled ESC w/Prog
Turnigy nano-tech 5300mah 2S2P 50~100C Hardcase (bought for my RC car, but also can be used in series for this boat)
HK's 435 Metal prop
HK's 440 Metal prop
As well as a bunch of other stuff like silicone wire, heatshrink, new XT60 connectors for everything.
I have setup the boat as best as I could, however when on it's maiden voyage, it emitted some strange behavior, but as I am in unfamiliar waters *ba doom tish* I am not sure what is causing the behavior.
Firstly, it seems to sit quite low in the water, I have attributed this to the batteries I have chosen weighing more than the boat can handle.
The second thing it does, is when I go 1/10th throttle, the boat goes along quite nicely, I give it a bit more stick and it picks up speed. I then give it some more from about 1/4 to 1/2 throttle and it starts to kind of slow downm, and looks and sounds like the prop has stopped pushing water, to rather milk-shaking it. like someone has thrown an anchor on it. but once I ho above half throttle up to about 3/4 it jumps up on plane and blasts along. It's very stable in turns even sharp ones, but if I don't give it full stick out of the turn it tends to bog down and looks like it's treading water for a bit until it jumps on plane.
Could all of this be attributed to too much weight, and it riding too low in the water? When I say low, I mean, the rudder is basically fully submerged when the boat is in the water.
Another problem I have had, is that the rudder water pickup does not seem to work, I couldn't see any water coming out the side outlet, and when I got the boat back to shore after a minute or so of driving, the tubes had only a drop or so of water in them. Could this also be attributed to the ride height in the water? I have seen where others have had to modify their rudders, making the inlet wider, so I might try that as well.
Anyway, thanks for reading! And hope you can help!
HK's 435 Metal prop
HK's 440 Metal prop
