So finally this amazing hull arrived from MHZ .The problem is that i got confused searcing which setup should i use and decided to ask for your help .I saw that some have used the powerfull scorpions 5035 outrunners and others the mega leopards 5692 or 5698.Can you make any suggestions for props and motor Kv range.The ESC will be the swordfish 240 HV.
New mystic 1380mm .What sould i put in there ?
So finally this amazing hull arrived from MHZ .The problem is that i got confused searcing which setup should i use and decided to ask for your help .I saw that some have used the powerfull scorpions 5035 outrunners and others the mega leopards 5692 or 5698.Can you make any suggestions for props and motor Kv range.The ESC will be the swordfish 240 HV. -
Turbine......X2!Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellersComment
You could easily work within that limit, if your talking pure motor and esc for $900 you could use 2x Fightercat 6 or 8s 300 amp esc's and your choice of motors is almost limitless, twin NEU 1521's, 1527's, Castle 1520's, 1717's, or even the TP power 5692's being relabeled by hobby king at the moment for $70 odd. If your meant with coolers, motor shaft adapters, wiring and connectors, well that probably rules out the neu's but most of the other motors could be done with accessories for under your budget=)
6BOOST6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturerComment
I have 2 NIB Castle 1717's for sale for $140 each. They have 6mm shafts. I have one Octura 6 x.187 collet Ill throw in if you want the motors. If you are outside of the U.S. , I ask thay you pay for the extra shipping. Let me know.Comment
6BOOSTComment
If your planning on using the Leo 5692 you should push more than 447 props as twin setup I think it would be safe in the high 50's if you are going to use the 240HV you might as well run 12s so the 730 kv should be perfect. Even the 3994 turnigy with 450/3 should push that hull I'm not a speed freak but I think you would be in the 120-130km/h markVisit www.customcfparts.com | Custom Boat Building | Custom Carbon Fiber Parts | Custom Graphics | LMT Premium Dealer | MGM Premium Dealer | YouTube | Facebook
"Follow someone's footsteps and you will always be a step behind"Comment
hi leopard15
Since you want a budget setup for your mystic, I would suggest getting the TP or leo 56xx with around 1300kv and powered by 6s lipo. prop would be good to start with x447's.Stiletto tunnel,EPV135 (53") twin cat, CT06"Spirit of Qatar", FD 47" mono, Twin Mini Cat 23.5"Comment
here is what i´ve done till nowComment
