Cat CG question
  • siberianhusky
    • Dec 2009
    • 2187
    Cat CG question
    First time I've built a boat with the transom overhangs.
    Do you determine the CG based on running surface length or total hull length including the overhang.
    H&M Drifter S.
    Thanks.
  • 6BOOST
    • Sep 2011
    • 286
    You are correct, work from the end of the ride surface to the tip boat and work your cg from there.
    6BOOST
    6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
    • siberianhusky
      • Dec 2009
      • 2187
      Thats what I thought, but easier to check now than change later.
      Thanks a bunch
      • bobkatz
        • Jul 2009
        • 56
        In order to get the cg close on my twin genesis the batteries need to be on the top of the tunnel, if I put the batteries in the sponson the cg moves to far forward. Which would be better, the correct cg or having the batteries as low as possible?
        I know I can add weight in the back to get the cg back but I don't want anymore weight then needed.
        • siberianhusky
          • Dec 2009
          • 2187
          Correct cg no question, boat won't run right with it wrong.
          • bobkatz
            • Jul 2009
            • 56
            I measured wrong for the cg, I measured total length, not running surface length. I can get the cg close with the batteries in the sponsons so will only need a little weight in the back to balance the boat. I can get the cg range between 27% thru 35%, that should be plenty for set up.
            Thanks for the help.
