what size prop
  • top shelf racing
    • 21
    what size prop
    hi what size carbon fiber propfrom ose should i use.it will be for a 22"deepvee with brushed 19 turn mtr. on 6 cells .most likely on str.shaft poss flex cable.mtr sits about 2"or less from transom.used only for sport racing.thank you for the help.water used on will mostly be small ponds poss from boat on lake when lakes calm.
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    I would suggest 27- 30mm diam. X 1.4 pitch
    Douggie
    • n.h.schmidt
      • May 2007
      • 39
      Props
      Hi I have some experience with this setup. A K31 or K33 would be about right. They do have 4mm threaded hubs though. For 1/8" dia shaft a Octura X431 or Y431 plastic would be good, cheap too. n.h.schmidt
