Further to my recent post regarding Rudder Pick up and Water Cooling Problem on my Genesis, I now have plenty of water flowing by increasing the size of the inlet slots at the bottom of the rudder (and removing the cooling from the front motor mount), but the 3mm Nylon safety screw (that is presumably there to stop you ripping the back of the boat off should the rudder hit something) is shearing, seemingly by itself without hitting anything, when at high speed. Last time I caught it before it sheared right through. It happened yesterday, and again today.
I don't think I hit anything or I would have expected it to shear right through. To me this looks like too much pressure on the nylon screw.
Could this be caused by the mods I did to the rudder, that is causing a lot more resistanse and drag in the water? Seems hard to believe it could make that much difference. Before and after photos below.
I have the main 4mm screw that the rudder pivots on, fairly loose and it does pivot quite easily (when the nylon screw is out). Should this screw be tighter?
Has anyone else had this nylon screw shearing in normal operation (i.e not due to the rudder hitting anything)?
I could go to a 4mm nylon screw but I am reluctant to do something that may result in damage if I do hit something and the screw doesn't shear when it should. Or perhaps I have just screwed up and should have left the rudder as it was -but it seemed worth trying at the time. Also, the suggestions of replacing the hinge with a brass tube prop wash pick up, or even the separate water pump seem to have plenty of merit.
Not sure what to do now
Any ideas?
Jon
Jon
