I have a big Sniper hull and have no idea how to mount the fake scoops. Anyone have any pointers on how to do it? I dont want to just rig it up. Looking for reliability.
Fake scoop mounting
Tags: None
Hey Larry, Id have to get some pics, but the way I did mine (not sniper but another hull) is I figured where I would want them and drilled a 1/4" hole. then epoxied the scoop over that hole. Once dry, I dremeled the material away to the inside of the scoop. then I used cut strips of cloth and resined it in so it will be bullet proof. This was on a hatch. I would do it similar on a deck as well, youd just have to dremel out material before the scoop was attached and work from the underside. In that case, I would glass the cloth strips int the scoop first and let them dry, leaving un-saturated strips of cloth hanging. then attach the scoop, let that cure, then go in and resin the remaining cloth up to the underside of the deck.
Hope that helps -
Successfully confused. I got it. Good idea. These go on the hatch, so should be easier than on the hull itself. Thanks.Comment
