EagleTree V2 - Corrupted Data??
  • Darin Jordan
    • 8335
    I tried to download some data from my EagleTree V2 and I'm getting a message saying that the "data appears to be corrupted" and that it can't download it... I REALLY want this data... Anyone else have this issue with these and, if so, was there a way, short of clearing the buffer, to fix it and actually read the data??
    HELP!
    Darin E. Jordan - Renton, WA
  • Rex R
    • 992
    the manual says that one can import the data into excel(spread sheet) as a text file) pg 6. that might let you save some data. apparently the 'epower' support forum is located somewhere at rcgroups... hth
    rex
    edit
    found the support forum here http://www.rcgroups.com/eagle-tree-systems-443/
    • Steven Vaccaro
      • 8723
      Darin give eagle tree sys a call on Monday they should have a answer.
      Steven Vaccaro
      • SJFE
        • 4735
        Darin I have got that on the dpr a couple times. The data was lost both times. In my case it was because I didn't clear mission data from the last time it was used. We are taking about diffrent units but maybe it will help in the future.
        Tom
        • Fast Guy
          • 135
          Make sure if you're set up for multiple models you are using the right one. Also if it was set up last time to use a temp probe and you didn't this time you will get corrupted data error.
