pirate 35 w/1520
This topic is closed.
  • steveo
    • 1454
    pirate 35 w/1520
    delta force pirate 35 with a 1520 on 5s i have only run the boat a few times and it handle well and not running wet i used a m445 prop with great temps but went to a x447 it taxed the batts hard and were alittle puffy but returned to normal batts are 5s 5000mah 30 zippys new. it ran 47mph on the x447 i did not get a chance to gps the 445 should i go up in pitch i did not think the 447 was to big
  • carlcisneros
    • Jan 2010
    • 1218
    go with battereis for one thing that are HIGHER "C" rated.
    you are deffinately taxing those IMO.
    • Make-a-Wake
      FE Rules!
      • 5557
      Yeah..............40c minimum with a 1520.
      Try an x645 for 5s.
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3278
        Run it on 6s with at least 40c packs and an X447/3. Speeds close to 60mph with cool temps on everything.
        • steveo
          • 1454
          thanks guys i thought i could get away with the 30c at the time the 40c were backordered, the 5s works well with my supercat i will use them in it
          today i was lokking at 6s turnigy nanos 45c 3300mah paralled packs what do you guys think
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            My experience is that nano techs are garbage. The regular blue turnigys perform better and last longer. The Pirate is a bigger boat that is just on the too big side for a 1520. Id run a Nue 1527/1.5/D on 6s. Even a 1/Y would work good. I use 3s 5000mah 40-50c for my 6s set ups.
            • Make-a-Wake
              FE Rules!
              • 5557
              I have read that the Nano's suck too. My humble opinion is that the 1520 will work well if not overpropped............so huge speed is not expected. With some 40c 5s batts and an x645 he should see 55 mph. If 6s is chosen then i would back off to the m445 and roughly the same speed should be attained. The 1520 is pretty stout and is larger than a Leopard 4082 for comparison..........its 40 x 88 mm. Make sure that you get 40c minimum batts.
              For 5s i'd run two of these in parallel - http://www.hobbyking.com/hobbyking/s...5S1P_40C_.html
              For 6s two of these in parallel - http://www.hobbyking.com/hobbyking/s...6S1P_40C_.html
              • steveo
                • 1454
                ok so let me understand this i have 2 5000mah 5s 30c batts good for 300 amps total and you say get the 40c 3000mah equal to 240 amps total does the higher c rating make all the difference i thought amps are amps not matter how they are obtained- maybe i did not state i had parallel packs which i thought would take the load i will try to back down props and some gps readings and temps, but still would like to go 6s
                • Make-a-Wake
                  FE Rules!
                  • 5557
                  I never knew you were running 2p..................... amperage is fine then. What ESC are you running? I still think an x645 on 5s would be nice.
                  • steveo
                    • 1454
                    esc is a t180 you know i cant remember what the lipo cut off is at maybe its on 4s and pulled the batts down to far thats why they puffed alittle along with the bigger prop i will look into it. i'm going to start with the m445 and check the speed then move up m545 then m645
                    • lenny
                      • Sep 2010
                      • 4294
                      Hey Stevo,
                      Did you get that DF 35 from Fastisgoood member ?LOL
                      ? ONLY IF THEY WORK
                      • steveo
                        • 1454
                        i plead the 5th
                        • lenny
                          • Sep 2010
                          • 4294
                          That is just not right.
                          Originally posted by steveo
                          i plead the 5th
                          http://forums.offshoreelectrics.com/...f-pirate-35-FS
                          ? ONLY IF THEY WORK
                          • steveo
                            • 1454
                            ha wow ayear ago- time flies
