Rail Mounts
  • Steven Vaccaro
    • 8723
    Rail Mounts
    Ok I'm looking to make some Neu Rail motor mounts. Do you guys use mostly a 4 or 5" rail widths?
  • txboatpilot
    • Oct 2007
    • 1494
    Please do both,, For Example, A Delta Force 33" can come with 4", and most of the bigger gas hulls have 5".... JMO
    Also 2/ sizes 15 and 22 series!
    Nothing like keeping you lipos warm and your prop wet!!
    • Steven Vaccaro
      • 8723
      15 and 22 series mounts are in the works in 4". What size boats are running 5" rails?
      • txboatpilot
        • Oct 2007
        • 1494
        All Aeromarine Gas boat hulls (36"-60") come with 5" rails.... The Avenger 44", Apache 50", XXX 45" V-hull, for example have 5"( unless you specail order for FE set-up).......Also Striker Cat's, Insane Hydros and Cat's....
        • hebner
          • 647
          I need mounts for DF33 with 4" rails, when will they be available?
          Hugh
          • Eyekandyboats
            • 1921
            Steve. i believe if you could make them 4 inches and then have " bolt" on extensions that would be great
            because i have a couple nitros with 4 inch rails and a gas one with 5inch that are all FE
            EYEKANDYGRAPHICS
            www.rclipos.com
            • Steven Vaccaro
              • 8723
              Ok, so I'm getting the vibs that nitro is spaced on a 4" rail. And gas is on a 5" rail? i will have both widths made.
              • Eyekandyboats
                • 1921
                thats the Norm Steve
                EYEKANDYGRAPHICS
                www.rclipos.com
                • blakybob
                  • 126
                  Steven, for what it's worth, I know of a couple very fast electric guys who order their stringers at 3". Makes a nice tight motor/esc bay with batts on outside of the rails.
                  If you go with the batts inside the rails with a 4" bay the lateral cg is better and with the motor mounted aft there's more room for longitudinal cg up front. The down side: the lipos I run are each about 1.9" wide so 4" inches would be a tight fit.
                  My 2 cents
                  Blake
                  • Bill-SOCAL
                    • Nov 2007
                    • 1405
                    Anything that uses a 22xx motor is going to have 5" rails. I just picked up a Stryker gas hydro hull to make FE. It has 5" rails. My Sniper is 5" as well (3060).
                    Are these going to be mounts that support the motor at both ends?? I feel that this is very important on any of the larger boats. Even my DF Storm is supported front and back. Solid mounting. No flexing.
                    Don't get me started
                    • SJFE
                      • 4735
                      Steven have you made any progress on these? I would like to get one for 45mm in the SW36. I'd have no problem testing a proto.
                      LMK
                      Thank's
                      Tom
