sport, no where to race 'round here. Oh I forgot thats right due to your new career. Sorry (dag on ADD). Dont worry about it he did some digging and found a set he ordered and forgot about.
Anyone ever built this?
Let us know what you plan for power, props etc. and the lads will chime in with their suggestions. State whether you wish run time over speed. note that even sport times are arround 4 minutes.
DouggieComment
ive realized that. Ill do some research tonight and get back to yall on my power and props all that fun stuff. (might need help with props).always need just a few mph moreComment
ESC- http://www.offshoreelectrics.com/pro...d=cas-hydra120
motor- http://www.offshoreelectrics.com/pro...prod=fei-540XL the 10xl?
battery- I want Li-Po not sure what C rating to get
Im not sure what prop to run? Also would all this stuff work together still kinda new to builds? Feel free to comment or change things. Thanks.always need just a few mph moreComment
The hull is 36" L and a KB45 motor would be a better choice. The ESC will depend on your motor and LI-Po set up. The hydra is limited to 5S max and the KB motors draw a lot of amps.
I suggest Kb45 10XL or 11XL, Hydra 120 or 240, 5000 mah 5S 25C, X640 or X445. you may wish to look at a high voltage ESC also.
DouggieLast edited by Flying Scotsman; 03-12-2008, 11:41 AM.Comment
thanks alot man that helped a ton. Ill look into this stuff. My brother said he will give me the ESC motor prop rudder and depending on the cable size hardware for 150$ (Just got off the phone with him). What cable size would yall reccomend im thinking .150 flex cable? One las thing what mount should i use with the kb-45 brushless motors? Thanks in advanceLast edited by justneedspeed; 03-12-2008, 04:26 PM.always need just a few mph moreComment
anyone know what mount i should use for this build? And .150 flex cable right? thanks in advanceLast edited by justneedspeed; 03-13-2008, 03:00 PM.always need just a few mph moreComment
I was thinking about building this hull my http://www.finedesignrc.com/hullshydromarine.asp
my brother had this and is going to give it to me becuase he doesnt want it. So any comment or reviews on thisthanks for any input.
Driven by 20-28 cells (33V) this is a very fast cat.
Even faster is the two motor set-up; Cat III Profi twinantrieb partnr. 11085.
If you have the experience and skill, go ahead, otherwise start with a milder set-up and work your way up. (An 800 on 24 cells can be very intimidating for starters...)
Regards, Jan.Comment
