Hello everybody,
I am getting ready to place a parts order for my 2 builds. Before I do, I would like some input please.
I am converting my Miss Budweiser to electric, It originally had a Dynamite .15 motor that turned 30 mph runs. the solid drive shaft is 8 1/2" x 1/8" (or 0.125) w/ 3/16" OD stuffing tube. The prop angle is non adjustable.
I was thinking of using this flex shaft, from here at OSE
Product ID: oct-oc098L-24c
Octura .098 cable system
In Stock: 8
Octura .098 flex cable with 1/8" prop shaft, drive dog, bullet nut and teflon liner.
We offer these unassembled or assembled.
Requires: 3/16 OD K&S brass tubing for stuffing tube when used with the Teflon liner.
I am unsure of the length of this shaft, and the motor limit for it as well.
I may be able to put a coupler on the solid druve shaft, but I prefer flex shafts.
If this wont be a feasible route, I can glass in a new tube and go with a ul-1 tube, shaft, coupler and adjustable strut ?.
I already removed the aluminum motor mounting blocks, so I can use an adjustable motor mount ?.
Any suggestions would be appreciated and Thanks
In Stock: 8
