Any tips for bending the pushrod, I dont want to snap it so thought id ask before i clamp it in a vice and get the mole-grips on it!
Bending Pushrod
Tags: None
Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
I made something similar to this, drilled 2 holes in a piece of steel and JB welded pieces of a broken drill bit shank in. Decided afterwards I shouldn't have glued one pin, could have drilled more holes. Mine will work with a 4-40 pushrod max because I glued the pins so close together.If my boats upside down then who owns the one I thought I was driving the last two laps?Comment
These wire benders from Du-Bro are great little tools... Make sure you get the right size for your wire diameter...
Later,
Mike BallComment
That's awesome! Bit pricey just to bend two bits of wire but I like having tools for every occasion so I may just splash outComment
For making the z-bends for a servo these pliers are great.
http://www.hobbyking.com/hobbyking/s...idProduct=6283Namba District 16
1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.Comment
With FE boats, I use stainless steel wire VS music wire. Both can be easily bent using a micro torch until red hot, then bend with needle nosed pliers. The wire will be softer, but will work fine for most FE applications. If you need stiffer wire - as in a HUGE rudder - just heat it to red hot at the bend and quench it in oil. I have a Z bend tool, but I love to play with fire. JIMJIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract SpecialistComment
