need help with motors
  • sean1982
    • Sep 2011
    • 12
    hi, is there a good water cooled motor that is the equivilent of the proboat 1500kv motor only shorter? like 60mm say?
    cheers
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    What hull, voltage, prop are you using it in?
    • sean1982
      • Sep 2011
      • 12
      hull is custom made mono, 790mm, havent got bateries or props yet. i have a hyperperformance leg that im altering to take a proboat engine cowl, so need a short motor.
      cheers
      • siberianhusky
        • Dec 2009
        • 2187
        Leopard 3650?
        • sean1982
          • Sep 2011
          • 12
          this be ok? http://www.ebay.co.uk/itm/1606726899...84.m1438.l2649
          what battery would be good with that?
          • JackBlack26
            • May 2007
            • 905
            I thought PB 1500kv was 3656, not 60mm.
            These are great motors!http://www.hobbyking.com/hobbyking/s...idProduct=6528
            • sean1982
              • Sep 2011
              • 12
              is the proboat motor 3656? i thought it was 74mm long??
              • JackBlack26
                • May 2007
                • 905
                No. It's not 74. Spec motors are 3656.
                • sean1982
                  • Sep 2011
                  • 12
                  cool! so the proboat motor should be fine then! what battery would go well with that? im using a seaking 180amp ESC too.
                  • siberianhusky
                    • Dec 2009
                    • 2187
                    53mm from the mounting face, 56 if you include the boss in the center where the shaft comes out. Just measured one.
                    • JackBlack26
                      • May 2007
                      • 905
                      1500kv will do fine with 4-6S. Just make sure they are at least 30C, 40 if less than 5000mah. In my Geico I always ran 4S, 2P though.
