hull build for delta force 29
  • sigelitest
    • Jul 2011
    • 329
    Ok So the wife is a Ten Vols Fan so I decided to set this hull up for her benefit
    Figured I would post the hull build
    IMG-20111104-00055.jpgIMG-20111104-00051.jpgIMG-20111104-00053.jpgIMG-20111104-00054.jpg
    Used an aluminum Brace covered in Velcro as a bat mount
    the lid is foamed with a pocked that is sized for the bat so it is solid.
    Used adhesive shrink wrap on the drive tube to keep the grease in and support the Teflon liner.
  • sigelitest
    • Jul 2011
    • 329
    I put the pics up out of order this was the start of the build
    IMG-20111020-00005.jpgIMG-20111019-00001.jpgIMG-20111019-00003.jpgIMG-20111020-00004.jpg
    Foamed this one using Us composites 2 part foam. Sprayed wd40 to keep the foam from sticking in the nose and sucking it in. After I J.B.welded the motor mount and the drive tube I glassed the inside of the hull. I moved the weight forward since this is a light hull.The bracing is soldered to the drive tube using a torch and then jb welded over the joint for extra strength.
    Setup info
    nemesis gold 4082 2200Kv
    octura 442 prop 4s
