CC1515 2200kv motor timing?
  • jasoncyclone
    • Jun 2011
    • 475
    I am going to program my 180a esc and am nt sure what to set the motor timing to? I am running a CC1515 2200kv, 180a esc, 2S2P turnigy 5000ma 40c, 42x55 AQ prop in my miss geico. Any one help me. I know not to use the auto function:)...Thanks Jason
    Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
  • m4a1usr
    Fast Electric Addict
    • 2038
    Typicaly 15 deg is right for "Y" motors. You could start conservatively, 10 deg, and see how the motor runs. Then increase if needed. There is no one setting for all speedos. Each is slightly different. But I wouldnt use anything lower than 10 deg to start.
    John
    Change is the one Constant
    • Rumdog
      • 6453
      I hope you meant 4s and not 2s2p. I'd go right to 15 degrees.
      • stadiumyamaha
        • 1284
        I run that same set up in several of my boat and set it to the 11.25 to be safe. Most run in low 50mph and the motor is in the 80deg esc under 100 and batts at about a buck ten but I run 4s2p which tends to run much cooler than 4s1p.
        white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
          Timing advance depends on the load placed on the motor. Light loads, 10 degrees. Normal "racing" loads, 15-20 degrees. In my SAW cat I ran 20 degrees advance on my 1515/1Y with 6S, and the motor and ESC were fine - but run time was very low. I picked up 3 mph going from 15 to 20 degrees, so on a normal setup the power difference will not be huge.
          • jasoncyclone
            • Jun 2011
            • 475
            Thanks guys. You are right, I meant to say 4s2p. I am currently running 15 deg with no problems. Motor and esc temp 85 deg. Batts are at 110 deg. This boat flies with this setup. Thanks for the replies. I will dial it back and see how she runs. If I lose 2-3 mph that will be ok. I would rather be safe than sorry.
