WHERE do I get this????
Tags: None
Right HERE
Don't (I repeat, Don't) use the stock OS cable with that coupler. Get some cables from either HERE or from Kris Flynn"A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -
Thank You Diego
How long the cable has to be to work with this coupler?
I have 3 Hyperformance cables that are 4.75 but they are way shorter than stock 5 1/8 inch cable.
When inside it looks like it is so short the coupler will not have enough to grip on...
Robert
Right HERE
Don't (I repeat, Don't) use the stock OS cable with that coupler. Get some cables from either HERE or from Kris FlynnDJI Drone Advanced Pilot
CanadaComment
The issue I had with the stock cable was with slop in the coupler. It doesn't fit right so it rounds out both the coupler and cable. I got cables from Kris, and they fit perfectly."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
