BL Electric Motor Maintenance?
  • megalops
    Fast Electric Freak
    • Aug 2011
    • 249
    I have read a couple of articles about whether or not brushless motors need maintenance. Some say that you should add a couple of drops of machine oil after every few runs. On the other hand I've read that the motors are pretty much maintenance fee. It stated that the bearings are "sealed and therefore should not be lubricated". I have a Leopard Motor if that makes a difference. Any info is appreciated.
    "If you can't win - Wreck someone who can!"
    • 8011
    Not all motors use the same kind of bearings. It does no harm to put a couple drops of good oil on the bearings after a day of use.
    • megalops
      Fast Electric Freak
      • Aug 2011
      • 249
      Thanks - Is 3 in 1 machine oil good?
        • 8011
        No it is not. I use this stuff, a high-quality bearing lubricant with an excellent applicator:
        • Alexgar
          • Aug 2009
          • 3534
          I use a couple different varieties of trinity bearing oil from my lhs
          • jkr
            FE Addiction
            • 568
            Trinity is a very good oil and i use it too.
            The bearings have grease from the factory.
            With the oil you will increase the max rpm of the bearings about 10k.
            The leopards (4074) use NSK 625-Z bearings
            • jkr
              FE Addiction
              • 568
              The leopards use NSK 625-Z bearings
              • megalops
                Fast Electric Freak
                • Aug 2011
                • 249
                Thanks for the info!
