Speedmaster Stinger Harware with Water flow problem- Low flow
  • sanyijr
    • 376
    I have this http://www.offshoreelectrics.com/pro...d=ros-mini-rud
    with http://www.offshoreelectrics.com/pro...os-stinger-str
    and it looks like this installed on my DF26 with X637 prop. http://forums.offshoreelectrics.com/...thomas-stealth Pic #1(thanks Phil for pic)
    Obviously not my boat, but same stinger to rudder proportions. Prop is set back from rudder. Water pickup is 1 inch below transom, but offset 1.5" from stinger/ "V" bottom of boat.
    Water pickup/output is very small. Sometimes at mid speed, 20-25 mph, still almost no water coming out. And I cannot figure why? There are NO kinked tubes. Resistance through cooling system is less that my Fastech, but flow is 50% of Fastech at best.
    Anyone have this issue? Has anyone modified the rudder for added pickup by adding the tapered cut into the rudder on both sides like http://forums.offshoreelectrics.com/...m-Quastion.... pst #12, pic #3. (thanks Darin) Where rudder cut is on both sides?
    Any suggestions?
  • MR2NR
    Jet Stream EP
    • Sep 2011
    • 159
    Is there.no water flow? If there is a steady stream that should be all you need. If it is spitting I would go to a larger intake and trim your lines to tue most direct route. This worked for me using a transom intake as well I go to a y that is closer to the esc and the other to the motor. Then run dual outlets out the back.
    I had flow issues as well until I modified as above now it works great.
    Kyosho K.I.T.T.
    • sanyijr
      • 376
      MR2NR, there is flow, but yes, spitting or sputtery. And sometimes none in even slight turns. The rudder is true to the direction of travel.
      • BrianW
        Rocket City Racing
        • Aug 2011
        • 90
        Something to do to optimize water flow is to take a very small round file and massage the opening in the rudder blade so that it is right to the leading edge of the blade.
        Any suggestions?
        • sanyijr
          • 376
          B,
          That is more like what I am lookiong for... I was going to Dremel the opening to the LE of the rudder and mirror that on the opposite side. But hve people done this with success is my question/concern?
          • BrianW
            Rocket City Racing
            • Aug 2011
            • 90
            It makes all on the difference in the world. They are machined that way so it takes a little work to make them very efficient
            • sanyijr
              • 376
              In that case, I have found my new project for tonight....... After Dinner, bath for kids, bedtime stories, cleaning kitchen.......a beer. But by then I will have re-evaluated and put it off till tomorrow. But the important part is I know what to do! Thanks
