I have a neu 1515 1y that stopped working the other day I think one of the poles is shot it will cog a little and then just stop. Where do you send it in for repairs and does anyone know what they charge?
Where to send neu motor to be repaired
You need to fill out a return authorization before you send the motor in, see below. The cost will depend on what is wrong with the motor, but Neu has an exchange policy - a used motor is worth 40% of the cost of a new one, so the most you'll ever pay is 60% of new.
I would suspect the esc first as well, not that motor. Unless you know that you ran it hot or some such. It is a common symptom for a bum esc, but not common for that motor to give out.Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco PowerComment
I've seen this many times from connectors that have become desoldered, the solder actually gets wicked up and into the esc wire. Leaving only the shrink wrap holding on the connector.Steven Vaccaro
First thing I checked was the esc it worked fine on my other motor. Steve and G unit hit it on the head only heat wrap holding on one of the connectors resoldered all connectors and bench tested, she now purrs like a kitten.
Thanks guys owe you a beer.
Come on down to lake of the ozarks to collect.
JeffComment
glad you figured it out. Upgrade to larger connectors.Steven Vaccaro
5.5mm connectors on most applications. 8.00 on the setups that are more than 150 amps.Steven Vaccaro
You may be pulling to many amps if you have 6.5 castles desoldering.Steven Vaccaro
If your setup warrants a 180A esc, then it makes sense to use (8mm) connectors that can handle that amperage as well. It will keep the resistance down, the wires and solder connections cooler, and you may even notice an increase in speed.Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco PowerComment
